Hi All,
when I read the ARM® Cortex -A Series Programmer’s Guide for ARMv7-A
I found that at page 8-12 Tabel 8-1 Cache features of Cortex-A series processors (continued)
there is a field say that Cortex-A7 cache line(words) is 8 and cache line(bytes) is 64
I'm confused about 1 word = 4 byte, but it seems that 1 word is 8 byte here
Is that a mistake or there is something I missed ?
And another question is why the Cortex-A12's cache line(words) is blank ?
Thanks for you guys help !
Regards,
Matt
I rate it a typo given the age of the document.The TRM for the CA7 says:
The L1 instruction memory system has the following features:• Instruction side cache line length of 32-bytes.
And:[3:0] IminLine Log2 of the number of words in the smallest cache line of all the instruction caches that the processor controls.0x3 Smallest instruction cache line size is 8 words.
For data:
The L1 data memory system has the following features:• Data side cache line length of 64-bytes.
[19:16] DminLine Log2 of the number of words in the smallest cache line of all the data and unified caches that the processor controls:0x4 Smallest data cache line size is 16 words.
Hi !
Thanks for your reply, after I check all the A-series TRM, I thought u r right, it may be a mistake.
Thanks a lot !
BR
