Given an interrupt that occurs at 500 microsecond intervals, write an interrupt handler that generates a square wave output by setting an interface bit high for a specific number of 500 microsecond periods and then sets the interface bit low for the same number of periods before repeating the process. The interface is at a location whose address is equated to the label GEN and the relevant bit is 0. How to approach this problem using assembly language ?
This question is far to general.
Do you have any experience writing assembly? Which core?
Check the compiler manual of the C compiler you are using. Most often they provide examples on how to write assembly routines.
