Assembling the NOP mnemonic as UAL will not change the functionality of the code, but will change:"¢ the instruction encoding selected"¢ the architecture variants on which the resulting binary will execute successfully, because the NOP instruction was introduced in ARMv6K and ARMv6T2.
mmmm10 NOP instructions on my beagle takes 2.508 s
anytime Etienne! though I quit ARMing
movw r0, #0x0500 @ you repeat your loop 83232000 times movt r0, #0x04F6.loop: nop @ here is you nop nop nop nop nop nop nop nop smuad r1, r1, r1 @ you can be sure the ending code take 5 cycles. nop nop smuad r2, r2, r2 nop subs r0, r0, #1 smuad r3, r3, r3 bgt .loop bx lr
movw r0, #0xB400 movt r0, #0x04C4
movw r0, #0x0500 movt r0, #0x04F6
mul r0, r1, r2mul r3, r4, r5
However, in cycle 2, it has nop instruction. Why does "nop" occur?
About NEOn instructions, how to know that 2 NEON instructions can be dual issue? Do they follow the rule you mentioned?
I read from specs that a Neon load/store instructions can be dual issued with SIMD data-processing instructions. So I tried below code in your website:vld1.32 {d0}, [r0]vadd d1, d2, d3
Is it right that if the next instruction uses Rd as operand, it has to wait after cycle #16 to start execution? If so, I think it is wasteful because if there no dependency, the next instruction may start execution at cycle #13 or #14.Is my thought right?Dung!
mov r0, #1 mov r10, #10000.loop: nop nop rsbs r0, r0, #1 beq .else subs r10, r10, #1 beq .exit nop nop b .loop.else subs r10, r10, #1 beq .exit nop nop b .loop.exit:
My purpose, I think, is just simple. I want to develop a tool to count the number of cycles to execute a short source code.I don't have a board or a Cortex-A8, I am just a man of theory (
Try setting up the timing function inside your program binary and measure a relatively large block of instructions so that the measurements overheads are small relative to the measurement.
I used above link to check cycles of some ARM instruction. However, I confused about the pipeline column.For example, there are "no, n1, 0, 1" that happen in 1 cycle. They seem to be stages of pipeline. However, Cortex-A8 has 13 stages of pipeline and there is no name like these name. Also, 1 stage takes 1 cycle, right?Please give me some explanations.
Dear Webshaker, I am thinking how to test the cycle count module of Cortex-A8. I think, for each instruction, I have to combine it with each other instruction to see how they work together.However, I got a problem. Because the number of instructions of Arm is too big, so the number of testcases is big too.Do you have other ideal for testing?
