Trace decompressor: Are barrier instructions and synchronization primitives really waypoints?
Dear all,
System: Altera Cyclone V with ARM Cortex-A9 dual-core MPU. CoreSight PFT 1.0
I am currently developing a trace decompressor. I wrote a function that parses the program image in order to get the waypoint information of each instruction.
This article on waypoints tells me to treat barrier instructions like direct branches:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ihi0035b/BCGJHDID.html
if i do that, my decoded stream is out of sync at the next i-sync packet. If i treat barrier instructions like non-waypoint-instructions, my decoded stream remains in sync.
The same is true for synchronization primitives.
I am wondering whats going on here, because the arm documentation usually is very reliable and these would be quite big mistakes, so what am i missing here? Can i really regard my decoded stream as valid only because my decompressor calculated the same address as the i-sync packet tells me?
Thank you!
