I'm pretty much new to this. I have Level 2 table (for ARMv8 - 64KB granule) with multiple 512MB block entries inside.Some of those blocks are not valid (belong to the reserved/not accessible memory).
Instead of them I've put INVALID entry with descriptor: 0x0000000000000002Problem is that when this invalid entry is hit (mis-predicted), VA address is translated to PA = 0x0 and cpu will try to read from 0x0.I thought it will dismiss this translation.
0x0000000000000002
PA = 0x0
0x0
Is there a way to declare this invalid entry to dismiss/not translate this address when it is hit?
With a 64K granule you should be having 3x lookup levels, namely level1, level2 and level3 and shouldn't be setting 0x2 at level3.
0, Reserved, invalidBehaves identically to encodings with bit[0] set to 0.This encoding must not be used in level 3 translation table
