I am porting Xilinx standalone drivers and libraries to armcc 6.7 compiler. I tried xilinx hello world applicationwith the ported code base (for cortexa53 processor), and obseverd that text section size is ~82 KB. However, if i compile same hello world application with gcc 7.3.1, text size appears to be ~30 KB .
Compiler flags details:
armclang 6.7:-O0 -g3 -mcpu=cortex-a53 --target=aarch64-arm-none-eabi
gcc 7.3.1:-O0 -g3
Note: Xilinx hello world application is built with the static library libxil.a, which consist of peripheral drivers. Said statict library is compiled with the optimization level O2 for gcc as well as armclang.
Executable size:
armclang 6.7:
text data bss dec hex 82248 96 16384 98728 181a8 gcc 7.3.1:
text data bss dec hex 30516 2344 20632 53492 d0f4 Attaching linker/scatter file and executable dump for gcc as well as armclang for reference. I am expecting text size to be around 25-30 KB. I went through armclang executable dump, except MMU tables mmu_tbl0,mmu_tbl1 and mmu_tbl2 (total size ~24KB), i didn't see any function which is taking > 1KB. Is this increase in code size due to code added by armclang compiler or am i missing something here?
Thanks,
Mubin
armclang_dump.txt
#! armclang --target=arm-arm-none-eabi -march=armv8-a -E -x c #define PSU_DDR_0_MEM_0_START 0x00000000 #define PSU_DDR_0_MEM_0_LENGTH 0x100000 #define ROM_SECTION_LENGTH 0x00020000 #define ROM_SECTION_START PSU_DDR_0_MEM_0_START #define DATA_SECTION_LENGTH 0x1000 #define DATA_SECTION_START_OFFSET 0 #define HEAP_SECTION_LENGTH 0x2000 #define HEAP_SECTION_START_OFFSET 0 #define STACK_SECTION_LENGTH 0x2000 #define STACK_SECTION_START (ROM_SECTION_START + ROM_SECTION_LENGTH + HEAP_SECTION_LENGTH + STACK_SECTION_LENGTH) PSU_DDR_0_MEM_0 PSU_DDR_0_MEM_0_START PSU_DDR_0_MEM_0_LENGTH { ROM_SECTION ROM_SECTION_START ROM_SECTION_LENGTH { asm_vectors.o (.vectors, +First) *(+RO) } DATA_SECTION +DATA_SECTION_START_OFFSET DATA_SECTION_LENGTH { *(+RW, +ZI) } ARM_LIB_HEAP +HEAP_SECTION_START_OFFSET ALIGN 64 EMPTY HEAP_SECTION_LENGTH { } ARM_LIB_STACK STACK_SECTION_START ALIGN 64 EMPTY -STACK_SECTION_LENGTH { } }
/*******************************************************************/ /* */ /* This file is automatically generated by linker script generator.*/ /* */ /* */ /* Copyright (c) 2010-2016 Xilinx, Inc. All rights reserved. */ /* */ /* Description : ARM v8 Linker Script */ /* */ /*******************************************************************/ _STACK_SIZE = DEFINED(_STACK_SIZE) ? _STACK_SIZE : 0x2000; _HEAP_SIZE = DEFINED(_HEAP_SIZE) ? _HEAP_SIZE : 0x2000; _EL0_STACK_SIZE = DEFINED(_EL0_STACK_SIZE) ? _EL0_STACK_SIZE : 1024; _EL1_STACK_SIZE = DEFINED(_EL1_STACK_SIZE) ? _EL1_STACK_SIZE : 2048; _EL2_STACK_SIZE = DEFINED(_EL2_STACK_SIZE) ? _EL2_STACK_SIZE : 1024; /* Define Memories in the system */ MEMORY { psu_ddr_0_MEM_0 : ORIGIN = 0x0, LENGTH = 0x7FF00000 psu_ddr_1_MEM_0 : ORIGIN = 0x800000000, LENGTH = 0x80000000 psu_ocm_ram_0_MEM_0 : ORIGIN = 0xFFFC0000, LENGTH = 0x40000 psu_qspi_linear_0_MEM_0 : ORIGIN = 0xC0000000, LENGTH = 0x20000000 } /* Specify the default entry point to the program */ ENTRY(_vector_table) /* Define the sections, and where they are mapped in memory */ SECTIONS { .text : { KEEP (*(.vectors)) *(.boot) *(.text) *(.text.*) *(.gnu.linkonce.t.*) *(.plt) *(.gnu_warning) *(.gcc_execpt_table) *(.glue_7) *(.glue_7t) *(.ARM.extab) *(.gnu.linkonce.armextab.*) } > psu_ddr_0_MEM_0 .init (ALIGN(64)) : { KEEP (*(.init)) } > psu_ddr_0_MEM_0 .fini (ALIGN(64)) : { KEEP (*(.fini)) } > psu_ddr_0_MEM_0 .interp : { KEEP (*(.interp)) } > psu_ddr_0_MEM_0 .note-ABI-tag : { KEEP (*(.note-ABI-tag)) } > psu_ddr_0_MEM_0 .rodata : { . = ALIGN(64); __rodata_start = .; *(.rodata) *(.rodata.*) *(.gnu.linkonce.r.*) __rodata_end = .; } > psu_ddr_0_MEM_0 .rodata1 : { . = ALIGN(64); __rodata1_start = .; *(.rodata1) *(.rodata1.*) __rodata1_end = .; } > psu_ddr_0_MEM_0 .sdata2 : { . = ALIGN(64); __sdata2_start = .; *(.sdata2) *(.sdata2.*) *(.gnu.linkonce.s2.*) __sdata2_end = .; } > psu_ddr_0_MEM_0 .sbss2 : { . = ALIGN(64); __sbss2_start = .; *(.sbss2) *(.sbss2.*) *(.gnu.linkonce.sb2.*) __sbss2_end = .; } > psu_ddr_0_MEM_0 .data : { . = ALIGN(64); __data_start = .; *(.data) *(.data.*) *(.gnu.linkonce.d.*) *(.jcr) *(.got) *(.got.plt) __data_end = .; } > psu_ddr_0_MEM_0 .data1 : { . = ALIGN(64); __data1_start = .; *(.data1) *(.data1.*) __data1_end = .; } > psu_ddr_0_MEM_0 .got : { *(.got) } > psu_ddr_0_MEM_0 .got1 : { *(.got1) } > psu_ddr_0_MEM_0 .got2 : { *(.got2) } > psu_ddr_0_MEM_0 .ctors : { . = ALIGN(64); __CTOR_LIST__ = .; ___CTORS_LIST___ = .; KEEP (*crtbegin.o(.ctors)) KEEP (*(EXCLUDE_FILE(*crtend.o) .ctors)) KEEP (*(SORT(.ctors.*))) KEEP (*(.ctors)) __CTOR_END__ = .; ___CTORS_END___ = .; } > psu_ddr_0_MEM_0 .dtors : { . = ALIGN(64); __DTOR_LIST__ = .; ___DTORS_LIST___ = .; KEEP (*crtbegin.o(.dtors)) KEEP (*(EXCLUDE_FILE(*crtend.o) .dtors)) KEEP (*(SORT(.dtors.*))) KEEP (*(.dtors)) __DTOR_END__ = .; ___DTORS_END___ = .; } > psu_ddr_0_MEM_0 .fixup : { __fixup_start = .; *(.fixup) __fixup_end = .; } > psu_ddr_0_MEM_0 .eh_frame : { *(.eh_frame) } > psu_ddr_0_MEM_0 .eh_framehdr : { __eh_framehdr_start = .; *(.eh_framehdr) __eh_framehdr_end = .; } > psu_ddr_0_MEM_0 .gcc_except_table : { *(.gcc_except_table) } > psu_ddr_0_MEM_0 .mmu_tbl0 (ALIGN(4096)) : { __mmu_tbl0_start = .; *(.mmu_tbl0) __mmu_tbl0_end = .; } > psu_ddr_0_MEM_0 .mmu_tbl1 (ALIGN(4096)) : { __mmu_tbl1_start = .; *(.mmu_tbl1) __mmu_tbl1_end = .; } > psu_ddr_0_MEM_0 .mmu_tbl2 (ALIGN(4096)) : { __mmu_tbl2_start = .; *(.mmu_tbl2) __mmu_tbl2_end = .; } > psu_ddr_0_MEM_0 .ARM.exidx : { __exidx_start = .; *(.ARM.exidx*) *(.gnu.linkonce.armexidix.*.*) __exidx_end = .; } > psu_ddr_0_MEM_0 .preinit_array : { . = ALIGN(64); __preinit_array_start = .; KEEP (*(SORT(.preinit_array.*))) KEEP (*(.preinit_array)) __preinit_array_end = .; } > psu_ddr_0_MEM_0 .init_array : { . = ALIGN(64); __init_array_start = .; KEEP (*(SORT(.init_array.*))) KEEP (*(.init_array)) __init_array_end = .; } > psu_ddr_0_MEM_0 .fini_array : { . = ALIGN(64); __fini_array_start = .; KEEP (*(SORT(.fini_array.*))) KEEP (*(.fini_array)) __fini_array_end = .; } > psu_ddr_0_MEM_0 .ARM.attributes : { __ARM.attributes_start = .; *(.ARM.attributes) __ARM.attributes_end = .; } > psu_ddr_0_MEM_0 .sdata : { . = ALIGN(64); __sdata_start = .; *(.sdata) *(.sdata.*) *(.gnu.linkonce.s.*) __sdata_end = .; } > psu_ddr_0_MEM_0 .sbss (NOLOAD) : { . = ALIGN(64); __sbss_start = .; *(.sbss) *(.sbss.*) *(.gnu.linkonce.sb.*) . = ALIGN(64); __sbss_end = .; } > psu_ddr_0_MEM_0 .tdata : { . = ALIGN(64); __tdata_start = .; *(.tdata) *(.tdata.*) *(.gnu.linkonce.td.*) __tdata_end = .; } > psu_ddr_0_MEM_0 .tbss : { . = ALIGN(64); __tbss_start = .; *(.tbss) *(.tbss.*) *(.gnu.linkonce.tb.*) __tbss_end = .; } > psu_ddr_0_MEM_0 .bss (NOLOAD) : { . = ALIGN(64); __bss_start__ = .; *(.bss) *(.bss.*) *(.gnu.linkonce.b.*) *(COMMON) . = ALIGN(64); __bss_end__ = .; } > psu_ddr_0_MEM_0 _SDA_BASE_ = __sdata_start + ((__sbss_end - __sdata_start) / 2 ); _SDA2_BASE_ = __sdata2_start + ((__sbss2_end - __sdata2_start) / 2 ); /* Generate Stack and Heap definitions */ .heap (NOLOAD) : { . = ALIGN(64); _heap = .; HeapBase = .; _heap_start = .; . += _HEAP_SIZE; _heap_end = .; HeapLimit = .; } > psu_ddr_0_MEM_0 .stack (NOLOAD) : { . = ALIGN(64); _el3_stack_end = .; . += _STACK_SIZE; __el3_stack = .; _el2_stack_end = .; . += _EL2_STACK_SIZE; . = ALIGN(64); __el2_stack = .; _el1_stack_end = .; . += _EL1_STACK_SIZE; . = ALIGN(64); __el1_stack = .; _el0_stack_end = .; . += _EL0_STACK_SIZE; . = ALIGN(64); __el0_stack = .; } > psu_ddr_0_MEM_0 _end = .; }
Check the map files, also the linker options. Likely gcc removes unused section whereas the ARM linker does not.
