Text section size for executable created with ARMCC 6.7 is more than expected
I am porting Xilinx standalone drivers and libraries to armcc 6.7 compiler. I tried xilinx hello world application
with the ported code base (for cortexa53 processor), and obseverd that text section size is ~82 KB. However, if i compile same hello world
application with gcc 7.3.1, text size appears to be ~30 KB .
Compiler flags details:
armclang 6.7:
-O0 -g3 -mcpu=cortex-a53 --target=aarch64-arm-none-eabi
gcc 7.3.1:
-O0 -g3
Note: Xilinx hello world application is built with the static library libxil.a, which consist of peripheral drivers. Said statict library is compiled with the optimization level O2 for gcc as well as armclang.
Executable size:
armclang 6.7:
text         data    bss       dec       hex
82248     96      16384   98728   181a8
gcc 7.3.1:
30516   2344    20632   53492   d0f4
Attaching linker/scatter file and executable dump for gcc as well as armclang for reference.
I am expecting text size to be around 25-30 KB. I went through  armclang executable dump, except MMU tables mmu_tbl0,mmu_tbl1 and mmu_tbl2 (total size ~24KB), i didn't see any function which is taking > 1KB.  Is this increase in code size due to  code added by armclang compiler or am i missing something here?
Thanks,
Mubin
armclang_dump.txt
scatter.scat.txt
#! armclang --target=arm-arm-none-eabi -march=armv8-a -E -x c
#define PSU_DDR_0_MEM_0_START  0x00000000
#define PSU_DDR_0_MEM_0_LENGTH 0x100000
#define ROM_SECTION_LENGTH          0x00020000
#define ROM_SECTION_START           PSU_DDR_0_MEM_0_START
#define DATA_SECTION_LENGTH          0x1000
#define DATA_SECTION_START_OFFSET    0
#define HEAP_SECTION_LENGTH         0x2000
#define HEAP_SECTION_START_OFFSET   0
#define STACK_SECTION_LENGTH        0x2000
#define STACK_SECTION_START         (ROM_SECTION_START + ROM_SECTION_LENGTH + HEAP_SECTION_LENGTH + STACK_SECTION_LENGTH)
PSU_DDR_0_MEM_0 PSU_DDR_0_MEM_0_START PSU_DDR_0_MEM_0_LENGTH
    ROM_SECTION ROM_SECTION_START ROM_SECTION_LENGTH
        asm_vectors.o (.vectors, +First)
        *(+RO)
    DATA_SECTION +DATA_SECTION_START_OFFSET DATA_SECTION_LENGTH
        *(+RW, +ZI)
    ARM_LIB_HEAP +HEAP_SECTION_START_OFFSET ALIGN 64 EMPTY HEAP_SECTION_LENGTH
    ARM_LIB_STACK STACK_SECTION_START ALIGN 64 EMPTY -STACK_SECTION_LENGTH
gcc_dump.txt
lscript.ld.txt
/* This file is automatically generated by linker script generator.*/
/* Copyright (c) 2010-2016 Xilinx, Inc.  All rights reserved.      */
/* Description : ARM v8 Linker Script                           */
_STACK_SIZE = DEFINED(_STACK_SIZE) ? _STACK_SIZE : 0x2000;
_HEAP_SIZE = DEFINED(_HEAP_SIZE) ? _HEAP_SIZE : 0x2000;
_EL0_STACK_SIZE = DEFINED(_EL0_STACK_SIZE) ? _EL0_STACK_SIZE : 1024;
_EL1_STACK_SIZE = DEFINED(_EL1_STACK_SIZE) ? _EL1_STACK_SIZE : 2048;
_EL2_STACK_SIZE = DEFINED(_EL2_STACK_SIZE) ? _EL2_STACK_SIZE : 1024;
/* Define Memories in the system */
MEMORY
   psu_ddr_0_MEM_0 : ORIGIN = 0x0, LENGTH = 0x7FF00000
   psu_ddr_1_MEM_0 : ORIGIN = 0x800000000, LENGTH = 0x80000000
   psu_ocm_ram_0_MEM_0 : ORIGIN = 0xFFFC0000, LENGTH = 0x40000
   psu_qspi_linear_0_MEM_0 : ORIGIN = 0xC0000000, LENGTH = 0x20000000
/* Specify the default entry point to the program */
ENTRY(_vector_table)
/* Define the sections, and where they are mapped in memory */
SECTIONS
.text : {
   KEEP (*(.vectors))
   *(.boot)
   *(.text)
   *(.text.*)
   *(.gnu.linkonce.t.*)
   *(.plt)
   *(.gnu_warning)
   *(.gcc_execpt_table)
   *(.glue_7)
   *(.glue_7t)
   *(.ARM.extab)
   *(.gnu.linkonce.armextab.*)
} > psu_ddr_0_MEM_0
.init (ALIGN(64)) : {
   KEEP (*(.init))
} > psu_ddr_0_MEM_0
.fini (ALIGN(64)) : {
   KEEP (*(.fini))
} > psu_ddr_0_MEM_0
.interp : {
   KEEP (*(.interp))
} > psu_ddr_0_MEM_0
.note-ABI-tag : {
   KEEP (*(.note-ABI-tag))
} > psu_ddr_0_MEM_0
.rodata : {
   . = ALIGN(64);
   __rodata_start = .;
   *(.rodata)
   *(.rodata.*)
   *(.gnu.linkonce.r.*)
   __rodata_end = .;
} > psu_ddr_0_MEM_0
.rodata1 : {
   . = ALIGN(64);
   __rodata1_start = .;
   *(.rodata1)
   *(.rodata1.*)
   __rodata1_end = .;
} > psu_ddr_0_MEM_0
.sdata2 : {
   . = ALIGN(64);
   __sdata2_start = .;
   *(.sdata2)
   *(.sdata2.*)
   *(.gnu.linkonce.s2.*)
   __sdata2_end = .;
} > psu_ddr_0_MEM_0
.sbss2 : {
   . = ALIGN(64);
   __sbss2_start = .;
   *(.sbss2)
   *(.sbss2.*)
   *(.gnu.linkonce.sb2.*)
   __sbss2_end = .;
} > psu_ddr_0_MEM_0
.data : {
   . = ALIGN(64);
   __data_start = .;
   *(.data)
   *(.data.*)
   *(.gnu.linkonce.d.*)
   *(.jcr)
   *(.got)
   *(.got.plt)
   __data_end = .;
} > psu_ddr_0_MEM_0
.data1 : {
   . = ALIGN(64);
   __data1_start = .;
   *(.data1)
   *(.data1.*)
   __data1_end = .;
} > psu_ddr_0_MEM_0
.got : {
   *(.got)
} > psu_ddr_0_MEM_0
.got1 : {
   *(.got1)
} > psu_ddr_0_MEM_0
.got2 : {
   *(.got2)
} > psu_ddr_0_MEM_0
.ctors : {
   . = ALIGN(64);
   __CTOR_LIST__ = .;
   ___CTORS_LIST___ = .;
   KEEP (*crtbegin.o(.ctors))
   KEEP (*(EXCLUDE_FILE(*crtend.o) .ctors))
   KEEP (*(SORT(.ctors.*)))
   KEEP (*(.ctors))
   __CTOR_END__ = .;
   ___CTORS_END___ = .;
} > psu_ddr_0_MEM_0
.dtors : {
   . = ALIGN(64);
   __DTOR_LIST__ = .;
   ___DTORS_LIST___ = .;
   KEEP (*crtbegin.o(.dtors))
   KEEP (*(EXCLUDE_FILE(*crtend.o) .dtors))
   KEEP (*(SORT(.dtors.*)))
   KEEP (*(.dtors))
   __DTOR_END__ = .;
   ___DTORS_END___ = .;
} > psu_ddr_0_MEM_0
.fixup : {
   __fixup_start = .;
   *(.fixup)
   __fixup_end = .;
} > psu_ddr_0_MEM_0
.eh_frame : {
   *(.eh_frame)
} > psu_ddr_0_MEM_0
.eh_framehdr : {
   __eh_framehdr_start = .;
   *(.eh_framehdr)
   __eh_framehdr_end = .;
} > psu_ddr_0_MEM_0
.gcc_except_table : {
   *(.gcc_except_table)
} > psu_ddr_0_MEM_0
.mmu_tbl0 (ALIGN(4096)) : {
   __mmu_tbl0_start = .;
   *(.mmu_tbl0)
   __mmu_tbl0_end = .;
} > psu_ddr_0_MEM_0
.mmu_tbl1 (ALIGN(4096)) : {
   __mmu_tbl1_start = .;
   *(.mmu_tbl1)
   __mmu_tbl1_end = .;
} > psu_ddr_0_MEM_0
.mmu_tbl2 (ALIGN(4096)) : {
   __mmu_tbl2_start = .;
   *(.mmu_tbl2)
   __mmu_tbl2_end = .;
} > psu_ddr_0_MEM_0
.ARM.exidx : {
   __exidx_start = .;
   *(.ARM.exidx*)
   *(.gnu.linkonce.armexidix.*.*)
   __exidx_end = .;
} > psu_ddr_0_MEM_0
.preinit_array : {
   . = ALIGN(64);
   __preinit_array_start = .;
   KEEP (*(SORT(.preinit_array.*)))
   KEEP (*(.preinit_array))
   __preinit_array_end = .;
} > psu_ddr_0_MEM_0
.init_array : {
   . = ALIGN(64);
   __init_array_start = .;
   KEEP (*(SORT(.init_array.*)))
   KEEP (*(.init_array))
   __init_array_end = .;
} > psu_ddr_0_MEM_0
.fini_array : {
   . = ALIGN(64);
   __fini_array_start = .;
   KEEP (*(SORT(.fini_array.*)))
   KEEP (*(.fini_array))
   __fini_array_end = .;
} > psu_ddr_0_MEM_0
.ARM.attributes : {
   __ARM.attributes_start = .;
   *(.ARM.attributes)
   __ARM.attributes_end = .;
} > psu_ddr_0_MEM_0
.sdata : {
   . = ALIGN(64);
   __sdata_start = .;
   *(.sdata)
   *(.sdata.*)
   *(.gnu.linkonce.s.*)
   __sdata_end = .;
} > psu_ddr_0_MEM_0
.sbss (NOLOAD) : {
   . = ALIGN(64);
   __sbss_start = .;
   *(.sbss)
   *(.sbss.*)
   *(.gnu.linkonce.sb.*)
   . = ALIGN(64);
   __sbss_end = .;
} > psu_ddr_0_MEM_0
.tdata : {
   . = ALIGN(64);
   __tdata_start = .;
   *(.tdata)
   *(.tdata.*)
   *(.gnu.linkonce.td.*)
   __tdata_end = .;
} > psu_ddr_0_MEM_0
.tbss : {
   . = ALIGN(64);
   __tbss_start = .;
   *(.tbss)
   *(.tbss.*)
   *(.gnu.linkonce.tb.*)
   __tbss_end = .;
} > psu_ddr_0_MEM_0
.bss (NOLOAD) : {
   . = ALIGN(64);
   __bss_start__ = .;
   *(.bss)
   *(.bss.*)
   *(.gnu.linkonce.b.*)
   *(COMMON)
   . = ALIGN(64);
   __bss_end__ = .;
} > psu_ddr_0_MEM_0
_SDA_BASE_ = __sdata_start + ((__sbss_end - __sdata_start) / 2 );
_SDA2_BASE_ = __sdata2_start + ((__sbss2_end - __sdata2_start) / 2 );
/* Generate Stack and Heap definitions */
.heap (NOLOAD) : {
   . = ALIGN(64);
   _heap = .;
   HeapBase = .;
   _heap_start = .;
   . += _HEAP_SIZE;
   _heap_end = .;
   HeapLimit = .;
} > psu_ddr_0_MEM_0
.stack (NOLOAD) : {
   . = ALIGN(64);
   _el3_stack_end = .;
   . += _STACK_SIZE;
   __el3_stack = .;
   _el2_stack_end = .;
   . += _EL2_STACK_SIZE;
   . = ALIGN(64);
   __el2_stack = .;
   _el1_stack_end = .;
   . += _EL1_STACK_SIZE;
   . = ALIGN(64);
   __el1_stack = .;
   _el0_stack_end = .;
   . += _EL0_STACK_SIZE;
   . = ALIGN(64);
   __el0_stack = .;
} > psu_ddr_0_MEM_0
_end = .;
