I'm trying to implement a spin-lock to synchronize the execution of all cores Cortex-A53 on my Xilinx-ZCU102 board, but I have some issues maybe due to a wrong configuration of the VMSA and cache coherence.
I'm writing bare-metal code, without the bsp provided by Xilinx. My software system is composed by:
I use xsct tool to download over JTAG and execute the software. The steps that i follow to boot are:
The boot completes correctly and my code takes the control in EL2-NS AArch64 execution state, so I create the translation table and configure the VMSA in this way:
TCR_EL1 = 0000001225192519 MAIR_EL1 = 00000004bb4400ff TTBR0_EL1 = 000000000800a000 TTBR1_EL1 = 0000000000000000 SCTLR_EL1 = 00c01805
As next action I ask to ATF, using the SMC CPU_ON, to launch the other cores at address 0x8000000. All the secondary cores start and they do the same configuration of the VMSA.
Following, there is an infinite loop in which the CPUs acquire a spin-lock, print a message over UART and release the spin-lock.
The problem is that only the CPU 0 can acquire the spin-lock. If I stop the execution after the spin-lock release of the CPU0, I can see that the lock variable for CPU0 is correctly 0 (unlockd), but the other CPUs see the value 1 (locked). So, if i try to dump he memory of the lock, using the xsct tool, the variable becomes 0 also for another CPU and resuming the execution, two CPUs can acquire and release the spin-lock.
Is this a cache coherence problem?
Other useful details are the following:
FUNCTION(spinlock_acquire) push_volatile_registers sp mov x29, sp sevl loop: wfe ldaxr w1, [x0] cbnz w1, loop mov w1, #1 stxr w2, w1, [x0] cbnz w2, loop pop_volatile_registers sp ret ENDFUNC(spinlock_acquire) FUNCTION(spinlock_release) stlr wzr, [x0] ret ENDFUNC(spinlock_release)
DESCRIPTOR: level 1 index: 000 --> 0000000000000e21 (0000000000000000) DESCRIPTOR: level 1 index: 001 --> 0000000040000e21 (0000000040000000) DESCRIPTOR: level 1 index: 002 --> 0060000080000405 (0000000080000000) DESCRIPTOR: level 1 index: 003 --> 800000000800b003 (000000000800b000) DESCRIPTOR: level 2 index: 000 --> 00600000c0000405 (00000000c0000000) DESCRIPTOR: level 2 index: 001 --> 00600000c0200405 (00000000c0200000) DESCRIPTOR: level 2 index: 002 --> 00600000c0400405 (00000000c0400000) DESCRIPTOR: level 2 index: 003 --> 00600000c0600405 (00000000c0600000) DESCRIPTOR: level 2 index: 004 --> 00600000c0800405 (00000000c0800000) DESCRIPTOR: level 2 index: 005 --> 00600000c0a00405 (00000000c0a00000) DESCRIPTOR: level 2 index: 006 --> 00600000c0c00405 (00000000c0c00000) DESCRIPTOR: level 2 index: 007 --> 00600000c0e00405 (00000000c0e00000) DESCRIPTOR: level 2 index: 008 --> 00600000c1000405 (00000000c1000000) DESCRIPTOR: level 2 index: 009 --> 00600000c1200405 (00000000c1200000) DESCRIPTOR: level 2 index: 010 --> 00600000c1400405 (00000000c1400000) DESCRIPTOR: level 2 index: 011 --> 00600000c1600405 (00000000c1600000) DESCRIPTOR: level 2 index: 012 --> 00600000c1800405 (00000000c1800000) DESCRIPTOR: level 2 index: 013 --> 00600000c1a00405 (00000000c1a00000) DESCRIPTOR: level 2 index: 014 --> 00600000c1c00405 (00000000c1c00000) DESCRIPTOR: level 2 index: 015 --> 00600000c1e00405 (00000000c1e00000) DESCRIPTOR: level 2 index: 016 --> 00600000c2000405 (00000000c2000000) DESCRIPTOR: level 2 index: 017 --> 00600000c2200405 (00000000c2200000) DESCRIPTOR: level 2 index: 018 --> 00600000c2400405 (00000000c2400000) DESCRIPTOR: level 2 index: 019 --> 00600000c2600405 (00000000c2600000) DESCRIPTOR: level 2 index: 020 --> 00600000c2800405 (00000000c2800000) DESCRIPTOR: level 2 index: 021 --> 00600000c2a00405 (00000000c2a00000) DESCRIPTOR: level 2 index: 022 --> 00600000c2c00405 (00000000c2c00000) DESCRIPTOR: level 2 index: 023 --> 00600000c2e00405 (00000000c2e00000) DESCRIPTOR: level 2 index: 024 --> 00600000c3000405 (00000000c3000000) DESCRIPTOR: level 2 index: 025 --> 00600000c3200405 (00000000c3200000) DESCRIPTOR: level 2 index: 026 --> 00600000c3400405 (00000000c3400000) DESCRIPTOR: level 2 index: 027 --> 00600000c3600405 (00000000c3600000) DESCRIPTOR: level 2 index: 028 --> 00600000c3800405 (00000000c3800000) DESCRIPTOR: level 2 index: 029 --> 00600000c3a00405 (00000000c3a00000) DESCRIPTOR: level 2 index: 030 --> 00600000c3c00405 (00000000c3c00000) DESCRIPTOR: level 2 index: 031 --> 00600000c3e00405 (00000000c3e00000) DESCRIPTOR: level 2 index: 032 --> 00600000c4000405 (00000000c4000000) DESCRIPTOR: level 2 index: 033 --> 00600000c4200405 (00000000c4200000) DESCRIPTOR: level 2 index: 034 --> 00600000c4400405 (00000000c4400000) DESCRIPTOR: level 2 index: 035 --> 00600000c4600405 (00000000c4600000) DESCRIPTOR: level 2 index: 036 --> 00600000c4800405 (00000000c4800000) DESCRIPTOR: level 2 index: 037 --> 00600000c4a00405 (00000000c4a00000) DESCRIPTOR: level 2 index: 038 --> 00600000c4c00405 (00000000c4c00000) DESCRIPTOR: level 2 index: 039 --> 00600000c4e00405 (00000000c4e00000) DESCRIPTOR: level 2 index: 040 --> 00600000c5000405 (00000000c5000000) DESCRIPTOR: level 2 index: 041 --> 00600000c5200405 (00000000c5200000) DESCRIPTOR: level 2 index: 042 --> 00600000c5400405 (00000000c5400000) DESCRIPTOR: level 2 index: 043 --> 00600000c5600405 (00000000c5600000) DESCRIPTOR: level 2 index: 044 --> 00600000c5800405 (00000000c5800000) DESCRIPTOR: level 2 index: 045 --> 00600000c5a00405 (00000000c5a00000) DESCRIPTOR: level 2 index: 046 --> 00600000c5c00405 (00000000c5c00000) DESCRIPTOR: level 2 index: 047 --> 00600000c5e00405 (00000000c5e00000) DESCRIPTOR: level 2 index: 048 --> 00600000c6000405 (00000000c6000000) DESCRIPTOR: level 2 index: 049 --> 00600000c6200405 (00000000c6200000) DESCRIPTOR: level 2 index: 050 --> 00600000c6400405 (00000000c6400000) DESCRIPTOR: level 2 index: 051 --> 00600000c6600405 (00000000c6600000) DESCRIPTOR: level 2 index: 052 --> 00600000c6800405 (00000000c6800000) DESCRIPTOR: level 2 index: 053 --> 00600000c6a00405 (00000000c6a00000) DESCRIPTOR: level 2 index: 054 --> 00600000c6c00405 (00000000c6c00000) DESCRIPTOR: level 2 index: 055 --> 00600000c6e00405 (00000000c6e00000) DESCRIPTOR: level 2 index: 056 --> 00600000c7000405 (00000000c7000000) DESCRIPTOR: level 2 index: 057 --> 00600000c7200405 (00000000c7200000) DESCRIPTOR: level 2 index: 058 --> 00600000c7400405 (00000000c7400000) DESCRIPTOR: level 2 index: 059 --> 00600000c7600405 (00000000c7600000) DESCRIPTOR: level 2 index: 060 --> 00600000c7800405 (00000000c7800000) DESCRIPTOR: level 2 index: 061 --> 00600000c7a00405 (00000000c7a00000) DESCRIPTOR: level 2 index: 062 --> 00600000c7c00405 (00000000c7c00000) DESCRIPTOR: level 2 index: 063 --> 00600000c7e00405 (00000000c7e00000) DESCRIPTOR: level 2 index: 064 --> 00600000c8000405 (00000000c8000000) DESCRIPTOR: level 2 index: 065 --> 00600000c8200405 (00000000c8200000) DESCRIPTOR: level 2 index: 066 --> 00600000c8400405 (00000000c8400000) DESCRIPTOR: level 2 index: 067 --> 00600000c8600405 (00000000c8600000) DESCRIPTOR: level 2 index: 068 --> 00600000c8800405 (00000000c8800000) DESCRIPTOR: level 2 index: 069 --> 00600000c8a00405 (00000000c8a00000) DESCRIPTOR: level 2 index: 070 --> 00600000c8c00405 (00000000c8c00000) DESCRIPTOR: level 2 index: 071 --> 00600000c8e00405 (00000000c8e00000) DESCRIPTOR: level 2 index: 072 --> 00600000c9000405 (00000000c9000000) DESCRIPTOR: level 2 index: 073 --> 00600000c9200405 (00000000c9200000) DESCRIPTOR: level 2 index: 074 --> 00600000c9400405 (00000000c9400000) DESCRIPTOR: level 2 index: 075 --> 00600000c9600405 (00000000c9600000) DESCRIPTOR: level 2 index: 076 --> 00600000c9800405 (00000000c9800000) DESCRIPTOR: level 2 index: 077 --> 00600000c9a00405 (00000000c9a00000) DESCRIPTOR: level 2 index: 078 --> 00600000c9c00405 (00000000c9c00000) DESCRIPTOR: level 2 index: 079 --> 00600000c9e00405 (00000000c9e00000) DESCRIPTOR: level 2 index: 080 --> 00600000ca000405 (00000000ca000000) DESCRIPTOR: level 2 index: 081 --> 00600000ca200405 (00000000ca200000) DESCRIPTOR: level 2 index: 082 --> 00600000ca400405 (00000000ca400000) DESCRIPTOR: level 2 index: 083 --> 00600000ca600405 (00000000ca600000) DESCRIPTOR: level 2 index: 084 --> 00600000ca800405 (00000000ca800000) DESCRIPTOR: level 2 index: 085 --> 00600000caa00405 (00000000caa00000) DESCRIPTOR: level 2 index: 086 --> 00600000cac00405 (00000000cac00000) DESCRIPTOR: level 2 index: 087 --> 00600000cae00405 (00000000cae00000) DESCRIPTOR: level 2 index: 088 --> 00600000cb000405 (00000000cb000000) DESCRIPTOR: level 2 index: 089 --> 00600000cb200405 (00000000cb200000) DESCRIPTOR: level 2 index: 090 --> 00600000cb400405 (00000000cb400000) DESCRIPTOR: level 2 index: 091 --> 00600000cb600405 (00000000cb600000) DESCRIPTOR: level 2 index: 092 --> 00600000cb800405 (00000000cb800000) DESCRIPTOR: level 2 index: 093 --> 00600000cba00405 (00000000cba00000) DESCRIPTOR: level 2 index: 094 --> 00600000cbc00405 (00000000cbc00000) DESCRIPTOR: level 2 index: 095 --> 00600000cbe00405 (00000000cbe00000) DESCRIPTOR: level 2 index: 096 --> 00600000cc000405 (00000000cc000000) DESCRIPTOR: level 2 index: 097 --> 00600000cc200405 (00000000cc200000) DESCRIPTOR: level 2 index: 098 --> 00600000cc400405 (00000000cc400000) DESCRIPTOR: level 2 index: 099 --> 00600000cc600405 (00000000cc600000) DESCRIPTOR: level 2 index: 100 --> 00600000cc800405 (00000000cc800000) DESCRIPTOR: level 2 index: 101 --> 00600000cca00405 (00000000cca00000) DESCRIPTOR: level 2 index: 102 --> 00600000ccc00405 (00000000ccc00000) DESCRIPTOR: level 2 index: 103 --> 00600000cce00405 (00000000cce00000) DESCRIPTOR: level 2 index: 104 --> 00600000cd000405 (00000000cd000000) DESCRIPTOR: level 2 index: 105 --> 00600000cd200405 (00000000cd200000) DESCRIPTOR: level 2 index: 106 --> 00600000cd400405 (00000000cd400000) DESCRIPTOR: level 2 index: 107 --> 00600000cd600405 (00000000cd600000) DESCRIPTOR: level 2 index: 108 --> 00600000cd800405 (00000000cd800000) DESCRIPTOR: level 2 index: 109 --> 00600000cda00405 (00000000cda00000) DESCRIPTOR: level 2 index: 110 --> 00600000cdc00405 (00000000cdc00000) DESCRIPTOR: level 2 index: 111 --> 00600000cde00405 (00000000cde00000) DESCRIPTOR: level 2 index: 112 --> 00600000ce000405 (00000000ce000000) DESCRIPTOR: level 2 index: 113 --> 00600000ce200405 (00000000ce200000) DESCRIPTOR: level 2 index: 114 --> 00600000ce400405 (00000000ce400000) DESCRIPTOR: level 2 index: 115 --> 00600000ce600405 (00000000ce600000) DESCRIPTOR: level 2 index: 116 --> 00600000ce800405 (00000000ce800000) DESCRIPTOR: level 2 index: 117 --> 00600000cea00405 (00000000cea00000) DESCRIPTOR: level 2 index: 118 --> 00600000cec00405 (00000000cec00000) DESCRIPTOR: level 2 index: 119 --> 00600000cee00405 (00000000cee00000) DESCRIPTOR: level 2 index: 120 --> 00600000cf000405 (00000000cf000000) DESCRIPTOR: level 2 index: 121 --> 00600000cf200405 (00000000cf200000) DESCRIPTOR: level 2 index: 122 --> 00600000cf400405 (00000000cf400000) DESCRIPTOR: level 2 index: 123 --> 00600000cf600405 (00000000cf600000) DESCRIPTOR: level 2 index: 124 --> 00600000cf800405 (00000000cf800000) DESCRIPTOR: level 2 index: 125 --> 00600000cfa00405 (00000000cfa00000) DESCRIPTOR: level 2 index: 126 --> 00600000cfc00405 (00000000cfc00000) DESCRIPTOR: level 2 index: 127 --> 00600000cfe00405 (00000000cfe00000) DESCRIPTOR: level 2 index: 128 --> 00600000d0000405 (00000000d0000000) DESCRIPTOR: level 2 index: 129 --> 00600000d0200405 (00000000d0200000) DESCRIPTOR: level 2 index: 130 --> 00600000d0400405 (00000000d0400000) DESCRIPTOR: level 2 index: 131 --> 00600000d0600405 (00000000d0600000) DESCRIPTOR: level 2 index: 132 --> 00600000d0800405 (00000000d0800000) DESCRIPTOR: level 2 index: 133 --> 00600000d0a00405 (00000000d0a00000) DESCRIPTOR: level 2 index: 134 --> 00600000d0c00405 (00000000d0c00000) DESCRIPTOR: level 2 index: 135 --> 00600000d0e00405 (00000000d0e00000) DESCRIPTOR: level 2 index: 136 --> 00600000d1000405 (00000000d1000000) DESCRIPTOR: level 2 index: 137 --> 00600000d1200405 (00000000d1200000) DESCRIPTOR: level 2 index: 138 --> 00600000d1400405 (00000000d1400000) DESCRIPTOR: level 2 index: 139 --> 00600000d1600405 (00000000d1600000) DESCRIPTOR: level 2 index: 140 --> 00600000d1800405 (00000000d1800000) DESCRIPTOR: level 2 index: 141 --> 00600000d1a00405 (00000000d1a00000) DESCRIPTOR: level 2 index: 142 --> 00600000d1c00405 (00000000d1c00000) DESCRIPTOR: level 2 index: 143 --> 00600000d1e00405 (00000000d1e00000) DESCRIPTOR: level 2 index: 144 --> 00600000d2000405 (00000000d2000000) DESCRIPTOR: level 2 index: 145 --> 00600000d2200405 (00000000d2200000) DESCRIPTOR: level 2 index: 146 --> 00600000d2400405 (00000000d2400000) DESCRIPTOR: level 2 index: 147 --> 00600000d2600405 (00000000d2600000) DESCRIPTOR: level 2 index: 148 --> 00600000d2800405 (00000000d2800000) DESCRIPTOR: level 2 index: 149 --> 00600000d2a00405 (00000000d2a00000) DESCRIPTOR: level 2 index: 150 --> 00600000d2c00405 (00000000d2c00000) DESCRIPTOR: level 2 index: 151 --> 00600000d2e00405 (00000000d2e00000) DESCRIPTOR: level 2 index: 152 --> 00600000d3000405 (00000000d3000000) DESCRIPTOR: level 2 index: 153 --> 00600000d3200405 (00000000d3200000) DESCRIPTOR: level 2 index: 154 --> 00600000d3400405 (00000000d3400000) DESCRIPTOR: level 2 index: 155 --> 00600000d3600405 (00000000d3600000) DESCRIPTOR: level 2 index: 156 --> 00600000d3800405 (00000000d3800000) DESCRIPTOR: level 2 index: 157 --> 00600000d3a00405 (00000000d3a00000) DESCRIPTOR: level 2 index: 158 --> 00600000d3c00405 (00000000d3c00000) DESCRIPTOR: level 2 index: 159 --> 00600000d3e00405 (00000000d3e00000) DESCRIPTOR: level 2 index: 160 --> 00600000d4000405 (00000000d4000000) DESCRIPTOR: level 2 index: 161 --> 00600000d4200405 (00000000d4200000) DESCRIPTOR: level 2 index: 162 --> 00600000d4400405 (00000000d4400000) DESCRIPTOR: level 2 index: 163 --> 00600000d4600405 (00000000d4600000) DESCRIPTOR: level 2 index: 164 --> 00600000d4800405 (00000000d4800000) DESCRIPTOR: level 2 index: 165 --> 00600000d4a00405 (00000000d4a00000) DESCRIPTOR: level 2 index: 166 --> 00600000d4c00405 (00000000d4c00000) DESCRIPTOR: level 2 index: 167 --> 00600000d4e00405 (00000000d4e00000) DESCRIPTOR: level 2 index: 168 --> 00600000d5000405 (00000000d5000000) DESCRIPTOR: level 2 index: 169 --> 00600000d5200405 (00000000d5200000) DESCRIPTOR: level 2 index: 170 --> 00600000d5400405 (00000000d5400000) DESCRIPTOR: level 2 index: 171 --> 00600000d5600405 (00000000d5600000) DESCRIPTOR: level 2 index: 172 --> 00600000d5800405 (00000000d5800000) DESCRIPTOR: level 2 index: 173 --> 00600000d5a00405 (00000000d5a00000) DESCRIPTOR: level 2 index: 174 --> 00600000d5c00405 (00000000d5c00000) DESCRIPTOR: level 2 index: 175 --> 00600000d5e00405 (00000000d5e00000) DESCRIPTOR: level 2 index: 176 --> 00600000d6000405 (00000000d6000000) DESCRIPTOR: level 2 index: 177 --> 00600000d6200405 (00000000d6200000) DESCRIPTOR: level 2 index: 178 --> 00600000d6400405 (00000000d6400000) DESCRIPTOR: level 2 index: 179 --> 00600000d6600405 (00000000d6600000) DESCRIPTOR: level 2 index: 180 --> 00600000d6800405 (00000000d6800000) DESCRIPTOR: level 2 index: 181 --> 00600000d6a00405 (00000000d6a00000) DESCRIPTOR: level 2 index: 182 --> 00600000d6c00405 (00000000d6c00000) DESCRIPTOR: level 2 index: 183 --> 00600000d6e00405 (00000000d6e00000) DESCRIPTOR: level 2 index: 184 --> 00600000d7000405 (00000000d7000000) DESCRIPTOR: level 2 index: 185 --> 00600000d7200405 (00000000d7200000) DESCRIPTOR: level 2 index: 186 --> 00600000d7400405 (00000000d7400000) DESCRIPTOR: level 2 index: 187 --> 00600000d7600405 (00000000d7600000) DESCRIPTOR: level 2 index: 188 --> 00600000d7800405 (00000000d7800000) DESCRIPTOR: level 2 index: 189 --> 00600000d7a00405 (00000000d7a00000) DESCRIPTOR: level 2 index: 190 --> 00600000d7c00405 (00000000d7c00000) DESCRIPTOR: level 2 index: 191 --> 00600000d7e00405 (00000000d7e00000) DESCRIPTOR: level 2 index: 192 --> 00600000d8000405 (00000000d8000000) DESCRIPTOR: level 2 index: 193 --> 00600000d8200405 (00000000d8200000) DESCRIPTOR: level 2 index: 194 --> 00600000d8400405 (00000000d8400000) DESCRIPTOR: level 2 index: 195 --> 00600000d8600405 (00000000d8600000) DESCRIPTOR: level 2 index: 196 --> 00600000d8800405 (00000000d8800000) DESCRIPTOR: level 2 index: 197 --> 00600000d8a00405 (00000000d8a00000) DESCRIPTOR: level 2 index: 198 --> 00600000d8c00405 (00000000d8c00000) DESCRIPTOR: level 2 index: 199 --> 00600000d8e00405 (00000000d8e00000) DESCRIPTOR: level 2 index: 200 --> 00600000d9000405 (00000000d9000000) DESCRIPTOR: level 2 index: 201 --> 00600000d9200405 (00000000d9200000) DESCRIPTOR: level 2 index: 202 --> 00600000d9400405 (00000000d9400000) DESCRIPTOR: level 2 index: 203 --> 00600000d9600405 (00000000d9600000) DESCRIPTOR: level 2 index: 204 --> 00600000d9800405 (00000000d9800000) DESCRIPTOR: level 2 index: 205 --> 00600000d9a00405 (00000000d9a00000) DESCRIPTOR: level 2 index: 206 --> 00600000d9c00405 (00000000d9c00000) DESCRIPTOR: level 2 index: 207 --> 00600000d9e00405 (00000000d9e00000) DESCRIPTOR: level 2 index: 208 --> 00600000da000405 (00000000da000000) DESCRIPTOR: level 2 index: 209 --> 00600000da200405 (00000000da200000) DESCRIPTOR: level 2 index: 210 --> 00600000da400405 (00000000da400000) DESCRIPTOR: level 2 index: 211 --> 00600000da600405 (00000000da600000) DESCRIPTOR: level 2 index: 212 --> 00600000da800405 (00000000da800000) DESCRIPTOR: level 2 index: 213 --> 00600000daa00405 (00000000daa00000) DESCRIPTOR: level 2 index: 214 --> 00600000dac00405 (00000000dac00000) DESCRIPTOR: level 2 index: 215 --> 00600000dae00405 (00000000dae00000) DESCRIPTOR: level 2 index: 216 --> 00600000db000405 (00000000db000000) DESCRIPTOR: level 2 index: 217 --> 00600000db200405 (00000000db200000) DESCRIPTOR: level 2 index: 218 --> 00600000db400405 (00000000db400000) DESCRIPTOR: level 2 index: 219 --> 00600000db600405 (00000000db600000) DESCRIPTOR: level 2 index: 220 --> 00600000db800405 (00000000db800000) DESCRIPTOR: level 2 index: 221 --> 00600000dba00405 (00000000dba00000) DESCRIPTOR: level 2 index: 222 --> 00600000dbc00405 (00000000dbc00000) DESCRIPTOR: level 2 index: 223 --> 00600000dbe00405 (00000000dbe00000) DESCRIPTOR: level 2 index: 224 --> 00600000dc000405 (00000000dc000000) DESCRIPTOR: level 2 index: 225 --> 00600000dc200405 (00000000dc200000) DESCRIPTOR: level 2 index: 226 --> 00600000dc400405 (00000000dc400000) DESCRIPTOR: level 2 index: 227 --> 00600000dc600405 (00000000dc600000) DESCRIPTOR: level 2 index: 228 --> 00600000dc800405 (00000000dc800000) DESCRIPTOR: level 2 index: 229 --> 00600000dca00405 (00000000dca00000) DESCRIPTOR: level 2 index: 230 --> 00600000dcc00405 (00000000dcc00000) DESCRIPTOR: level 2 index: 231 --> 00600000dce00405 (00000000dce00000) DESCRIPTOR: level 2 index: 232 --> 00600000dd000405 (00000000dd000000) DESCRIPTOR: level 2 index: 233 --> 00600000dd200405 (00000000dd200000) DESCRIPTOR: level 2 index: 234 --> 00600000dd400405 (00000000dd400000) DESCRIPTOR: level 2 index: 235 --> 00600000dd600405 (00000000dd600000) DESCRIPTOR: level 2 index: 236 --> 00600000dd800405 (00000000dd800000) DESCRIPTOR: level 2 index: 237 --> 00600000dda00405 (00000000dda00000) DESCRIPTOR: level 2 index: 238 --> 00600000ddc00405 (00000000ddc00000) DESCRIPTOR: level 2 index: 239 --> 00600000dde00405 (00000000dde00000) DESCRIPTOR: level 2 index: 240 --> 00600000de000405 (00000000de000000) DESCRIPTOR: level 2 index: 241 --> 00600000de200405 (00000000de200000) DESCRIPTOR: level 2 index: 242 --> 00600000de400405 (00000000de400000) DESCRIPTOR: level 2 index: 243 --> 00600000de600405 (00000000de600000) DESCRIPTOR: level 2 index: 244 --> 00600000de800405 (00000000de800000) DESCRIPTOR: level 2 index: 245 --> 00600000dea00405 (00000000dea00000) DESCRIPTOR: level 2 index: 246 --> 00600000dec00405 (00000000dec00000) DESCRIPTOR: level 2 index: 247 --> 00600000dee00405 (00000000dee00000) DESCRIPTOR: level 2 index: 248 --> 00600000df000405 (00000000df000000) DESCRIPTOR: level 2 index: 249 --> 00600000df200405 (00000000df200000) DESCRIPTOR: level 2 index: 250 --> 00600000df400405 (00000000df400000) DESCRIPTOR: level 2 index: 251 --> 00600000df600405 (00000000df600000) DESCRIPTOR: level 2 index: 252 --> 00600000df800405 (00000000df800000) DESCRIPTOR: level 2 index: 253 --> 00600000dfa00405 (00000000dfa00000) DESCRIPTOR: level 2 index: 254 --> 00600000dfc00405 (00000000dfc00000) DESCRIPTOR: level 2 index: 255 --> 00600000dfe00405 (00000000dfe00000) DESCRIPTOR: level 2 index: 256 --> 00600000e0000405 (00000000e0000000) DESCRIPTOR: level 2 index: 257 --> 00600000e0200405 (00000000e0200000) DESCRIPTOR: level 2 index: 258 --> 00600000e0400405 (00000000e0400000) DESCRIPTOR: level 2 index: 259 --> 00600000e0600405 (00000000e0600000) DESCRIPTOR: level 2 index: 260 --> 00600000e0800405 (00000000e0800000) DESCRIPTOR: level 2 index: 261 --> 00600000e0a00405 (00000000e0a00000) DESCRIPTOR: level 2 index: 262 --> 00600000e0c00405 (00000000e0c00000) DESCRIPTOR: level 2 index: 263 --> 00600000e0e00405 (00000000e0e00000) DESCRIPTOR: level 2 index: 264 --> 00600000e1000405 (00000000e1000000) DESCRIPTOR: level 2 index: 265 --> 00600000e1200405 (00000000e1200000) DESCRIPTOR: level 2 index: 266 --> 00600000e1400405 (00000000e1400000) DESCRIPTOR: level 2 index: 267 --> 00600000e1600405 (00000000e1600000) DESCRIPTOR: level 2 index: 268 --> 00600000e1800405 (00000000e1800000) DESCRIPTOR: level 2 index: 269 --> 00600000e1a00405 (00000000e1a00000) DESCRIPTOR: level 2 index: 270 --> 00600000e1c00405 (00000000e1c00000) DESCRIPTOR: level 2 index: 271 --> 00600000e1e00405 (00000000e1e00000) DESCRIPTOR: level 2 index: 272 --> 00600000e2000405 (00000000e2000000) DESCRIPTOR: level 2 index: 273 --> 00600000e2200405 (00000000e2200000) DESCRIPTOR: level 2 index: 274 --> 00600000e2400405 (00000000e2400000) DESCRIPTOR: level 2 index: 275 --> 00600000e2600405 (00000000e2600000) DESCRIPTOR: level 2 index: 276 --> 00600000e2800405 (00000000e2800000) DESCRIPTOR: level 2 index: 277 --> 00600000e2a00405 (00000000e2a00000) DESCRIPTOR: level 2 index: 278 --> 00600000e2c00405 (00000000e2c00000) DESCRIPTOR: level 2 index: 279 --> 00600000e2e00405 (00000000e2e00000) DESCRIPTOR: level 2 index: 280 --> 00600000e3000405 (00000000e3000000) DESCRIPTOR: level 2 index: 281 --> 00600000e3200405 (00000000e3200000) DESCRIPTOR: level 2 index: 282 --> 00600000e3400405 (00000000e3400000) DESCRIPTOR: level 2 index: 283 --> 00600000e3600405 (00000000e3600000) DESCRIPTOR: level 2 index: 284 --> 00600000e3800405 (00000000e3800000) DESCRIPTOR: level 2 index: 285 --> 00600000e3a00405 (00000000e3a00000) DESCRIPTOR: level 2 index: 286 --> 00600000e3c00405 (00000000e3c00000) DESCRIPTOR: level 2 index: 287 --> 00600000e3e00405 (00000000e3e00000) DESCRIPTOR: level 2 index: 288 --> 00600000e4000405 (00000000e4000000) DESCRIPTOR: level 2 index: 289 --> 00600000e4200405 (00000000e4200000) DESCRIPTOR: level 2 index: 290 --> 00600000e4400405 (00000000e4400000) DESCRIPTOR: level 2 index: 291 --> 00600000e4600405 (00000000e4600000) DESCRIPTOR: level 2 index: 292 --> 00600000e4800405 (00000000e4800000) DESCRIPTOR: level 2 index: 293 --> 00600000e4a00405 (00000000e4a00000) DESCRIPTOR: level 2 index: 294 --> 00600000e4c00405 (00000000e4c00000) DESCRIPTOR: level 2 index: 295 --> 00600000e4e00405 (00000000e4e00000) DESCRIPTOR: level 2 index: 296 --> 00600000e5000405 (00000000e5000000) DESCRIPTOR: level 2 index: 297 --> 00600000e5200405 (00000000e5200000) DESCRIPTOR: level 2 index: 298 --> 00600000e5400405 (00000000e5400000) DESCRIPTOR: level 2 index: 299 --> 00600000e5600405 (00000000e5600000) DESCRIPTOR: level 2 index: 300 --> 00600000e5800405 (00000000e5800000) DESCRIPTOR: level 2 index: 301 --> 00600000e5a00405 (00000000e5a00000) DESCRIPTOR: level 2 index: 302 --> 00600000e5c00405 (00000000e5c00000) DESCRIPTOR: level 2 index: 303 --> 00600000e5e00405 (00000000e5e00000) DESCRIPTOR: level 2 index: 304 --> 00600000e6000405 (00000000e6000000) DESCRIPTOR: level 2 index: 305 --> 00600000e6200405 (00000000e6200000) DESCRIPTOR: level 2 index: 306 --> 00600000e6400405 (00000000e6400000) DESCRIPTOR: level 2 index: 307 --> 00600000e6600405 (00000000e6600000) DESCRIPTOR: level 2 index: 308 --> 00600000e6800405 (00000000e6800000) DESCRIPTOR: level 2 index: 309 --> 00600000e6a00405 (00000000e6a00000) DESCRIPTOR: level 2 index: 310 --> 00600000e6c00405 (00000000e6c00000) DESCRIPTOR: level 2 index: 311 --> 00600000e6e00405 (00000000e6e00000) DESCRIPTOR: level 2 index: 312 --> 00600000e7000405 (00000000e7000000) DESCRIPTOR: level 2 index: 313 --> 00600000e7200405 (00000000e7200000) DESCRIPTOR: level 2 index: 314 --> 00600000e7400405 (00000000e7400000) DESCRIPTOR: level 2 index: 315 --> 00600000e7600405 (00000000e7600000) DESCRIPTOR: level 2 index: 316 --> 00600000e7800405 (00000000e7800000) DESCRIPTOR: level 2 index: 317 --> 00600000e7a00405 (00000000e7a00000) DESCRIPTOR: level 2 index: 318 --> 00600000e7c00405 (00000000e7c00000) DESCRIPTOR: level 2 index: 319 --> 00600000e7e00405 (00000000e7e00000) DESCRIPTOR: level 2 index: 320 --> 00600000e8000405 (00000000e8000000) DESCRIPTOR: level 2 index: 321 --> 00600000e8200405 (00000000e8200000) DESCRIPTOR: level 2 index: 322 --> 00600000e8400405 (00000000e8400000) DESCRIPTOR: level 2 index: 323 --> 00600000e8600405 (00000000e8600000) DESCRIPTOR: level 2 index: 324 --> 00600000e8800405 (00000000e8800000) DESCRIPTOR: level 2 index: 325 --> 00600000e8a00405 (00000000e8a00000) DESCRIPTOR: level 2 index: 326 --> 00600000e8c00405 (00000000e8c00000) DESCRIPTOR: level 2 index: 327 --> 00600000e8e00405 (00000000e8e00000) DESCRIPTOR: level 2 index: 328 --> 00600000e9000405 (00000000e9000000) DESCRIPTOR: level 2 index: 329 --> 00600000e9200405 (00000000e9200000) DESCRIPTOR: level 2 index: 330 --> 00600000e9400405 (00000000e9400000) DESCRIPTOR: level 2 index: 331 --> 00600000e9600405 (00000000e9600000) DESCRIPTOR: level 2 index: 332 --> 00600000e9800405 (00000000e9800000) DESCRIPTOR: level 2 index: 333 --> 00600000e9a00405 (00000000e9a00000) DESCRIPTOR: level 2 index: 334 --> 00600000e9c00405 (00000000e9c00000) DESCRIPTOR: level 2 index: 335 --> 00600000e9e00405 (00000000e9e00000) DESCRIPTOR: level 2 index: 336 --> 00600000ea000405 (00000000ea000000) DESCRIPTOR: level 2 index: 337 --> 00600000ea200405 (00000000ea200000) DESCRIPTOR: level 2 index: 338 --> 00600000ea400405 (00000000ea400000) DESCRIPTOR: level 2 index: 339 --> 00600000ea600405 (00000000ea600000) DESCRIPTOR: level 2 index: 340 --> 00600000ea800405 (00000000ea800000) DESCRIPTOR: level 2 index: 341 --> 00600000eaa00405 (00000000eaa00000) DESCRIPTOR: level 2 index: 342 --> 00600000eac00405 (00000000eac00000) DESCRIPTOR: level 2 index: 343 --> 00600000eae00405 (00000000eae00000) DESCRIPTOR: level 2 index: 344 --> 00600000eb000405 (00000000eb000000) DESCRIPTOR: level 2 index: 345 --> 00600000eb200405 (00000000eb200000) DESCRIPTOR: level 2 index: 346 --> 00600000eb400405 (00000000eb400000) DESCRIPTOR: level 2 index: 347 --> 00600000eb600405 (00000000eb600000) DESCRIPTOR: level 2 index: 348 --> 00600000eb800405 (00000000eb800000) DESCRIPTOR: level 2 index: 349 --> 00600000eba00405 (00000000eba00000) DESCRIPTOR: level 2 index: 350 --> 00600000ebc00405 (00000000ebc00000) DESCRIPTOR: level 2 index: 351 --> 00600000ebe00405 (00000000ebe00000) DESCRIPTOR: level 2 index: 352 --> 00600000ec000405 (00000000ec000000) DESCRIPTOR: level 2 index: 353 --> 00600000ec200405 (00000000ec200000) DESCRIPTOR: level 2 index: 354 --> 00600000ec400405 (00000000ec400000) DESCRIPTOR: level 2 index: 355 --> 00600000ec600405 (00000000ec600000) DESCRIPTOR: level 2 index: 356 --> 00600000ec800405 (00000000ec800000) DESCRIPTOR: level 2 index: 357 --> 00600000eca00405 (00000000eca00000) DESCRIPTOR: level 2 index: 358 --> 00600000ecc00405 (00000000ecc00000) DESCRIPTOR: level 2 index: 359 --> 00600000ece00405 (00000000ece00000) DESCRIPTOR: level 2 index: 360 --> 00600000ed000405 (00000000ed000000) DESCRIPTOR: level 2 index: 361 --> 00600000ed200405 (00000000ed200000) DESCRIPTOR: level 2 index: 362 --> 00600000ed400405 (00000000ed400000) DESCRIPTOR: level 2 index: 363 --> 00600000ed600405 (00000000ed600000) DESCRIPTOR: level 2 index: 364 --> 00600000ed800405 (00000000ed800000) DESCRIPTOR: level 2 index: 365 --> 00600000eda00405 (00000000eda00000) DESCRIPTOR: level 2 index: 366 --> 00600000edc00405 (00000000edc00000) DESCRIPTOR: level 2 index: 367 --> 00600000ede00405 (00000000ede00000) DESCRIPTOR: level 2 index: 368 --> 00600000ee000405 (00000000ee000000) DESCRIPTOR: level 2 index: 369 --> 00600000ee200405 (00000000ee200000) DESCRIPTOR: level 2 index: 370 --> 00600000ee400405 (00000000ee400000) DESCRIPTOR: level 2 index: 371 --> 00600000ee600405 (00000000ee600000) DESCRIPTOR: level 2 index: 372 --> 00600000ee800405 (00000000ee800000) DESCRIPTOR: level 2 index: 373 --> 00600000eea00405 (00000000eea00000) DESCRIPTOR: level 2 index: 374 --> 00600000eec00405 (00000000eec00000) DESCRIPTOR: level 2 index: 375 --> 00600000eee00405 (00000000eee00000) DESCRIPTOR: level 2 index: 376 --> 00600000ef000405 (00000000ef000000) DESCRIPTOR: level 2 index: 377 --> 00600000ef200405 (00000000ef200000) DESCRIPTOR: level 2 index: 378 --> 00600000ef400405 (00000000ef400000) DESCRIPTOR: level 2 index: 379 --> 00600000ef600405 (00000000ef600000) DESCRIPTOR: level 2 index: 380 --> 00600000ef800405 (00000000ef800000) DESCRIPTOR: level 2 index: 381 --> 00600000efa00405 (00000000efa00000) DESCRIPTOR: level 2 index: 382 --> 00600000efc00405 (00000000efc00000) DESCRIPTOR: level 2 index: 383 --> 00600000efe00405 (00000000efe00000) DESCRIPTOR: level 2 index: 384 --> 00600000f0000005 (00000000f0000000) DESCRIPTOR: level 2 index: 385 --> 00600000f0200005 (00000000f0200000) DESCRIPTOR: level 2 index: 386 --> 00600000f0400005 (00000000f0400000) DESCRIPTOR: level 2 index: 387 --> 00600000f0600005 (00000000f0600000) DESCRIPTOR: level 2 index: 388 --> 00600000f0800005 (00000000f0800000) DESCRIPTOR: level 2 index: 389 --> 00600000f0a00005 (00000000f0a00000) DESCRIPTOR: level 2 index: 390 --> 00600000f0c00005 (00000000f0c00000) DESCRIPTOR: level 2 index: 391 --> 00600000f0e00005 (00000000f0e00000) DESCRIPTOR: level 2 index: 392 --> 00600000f1000005 (00000000f1000000) DESCRIPTOR: level 2 index: 393 --> 00600000f1200005 (00000000f1200000) DESCRIPTOR: level 2 index: 394 --> 00600000f1400005 (00000000f1400000) DESCRIPTOR: level 2 index: 395 --> 00600000f1600005 (00000000f1600000) DESCRIPTOR: level 2 index: 396 --> 00600000f1800005 (00000000f1800000) DESCRIPTOR: level 2 index: 397 --> 00600000f1a00005 (00000000f1a00000) DESCRIPTOR: level 2 index: 398 --> 00600000f1c00005 (00000000f1c00000) DESCRIPTOR: level 2 index: 399 --> 00600000f1e00005 (00000000f1e00000) DESCRIPTOR: level 2 index: 400 --> 00600000f2000005 (00000000f2000000) DESCRIPTOR: level 2 index: 401 --> 00600000f2200005 (00000000f2200000) DESCRIPTOR: level 2 index: 402 --> 00600000f2400005 (00000000f2400000) DESCRIPTOR: level 2 index: 403 --> 00600000f2600005 (00000000f2600000) DESCRIPTOR: level 2 index: 404 --> 00600000f2800005 (00000000f2800000) DESCRIPTOR: level 2 index: 405 --> 00600000f2a00005 (00000000f2a00000) DESCRIPTOR: level 2 index: 406 --> 00600000f2c00005 (00000000f2c00000) DESCRIPTOR: level 2 index: 407 --> 00600000f2e00005 (00000000f2e00000) DESCRIPTOR: level 2 index: 408 --> 00600000f3000005 (00000000f3000000) DESCRIPTOR: level 2 index: 409 --> 00600000f3200005 (00000000f3200000) DESCRIPTOR: level 2 index: 410 --> 00600000f3400005 (00000000f3400000) DESCRIPTOR: level 2 index: 411 --> 00600000f3600005 (00000000f3600000) DESCRIPTOR: level 2 index: 412 --> 00600000f3800005 (00000000f3800000) DESCRIPTOR: level 2 index: 413 --> 00600000f3a00005 (00000000f3a00000) DESCRIPTOR: level 2 index: 414 --> 00600000f3c00005 (00000000f3c00000) DESCRIPTOR: level 2 index: 415 --> 00600000f3e00005 (00000000f3e00000) DESCRIPTOR: level 2 index: 416 --> 00600000f4000005 (00000000f4000000) DESCRIPTOR: level 2 index: 417 --> 00600000f4200005 (00000000f4200000) DESCRIPTOR: level 2 index: 418 --> 00600000f4400005 (00000000f4400000) DESCRIPTOR: level 2 index: 419 --> 00600000f4600005 (00000000f4600000) DESCRIPTOR: level 2 index: 420 --> 00600000f4800005 (00000000f4800000) DESCRIPTOR: level 2 index: 421 --> 00600000f4a00005 (00000000f4a00000) DESCRIPTOR: level 2 index: 422 --> 00600000f4c00005 (00000000f4c00000) DESCRIPTOR: level 2 index: 423 --> 00600000f4e00005 (00000000f4e00000) DESCRIPTOR: level 2 index: 424 --> 00600000f5000005 (00000000f5000000) DESCRIPTOR: level 2 index: 425 --> 00600000f5200005 (00000000f5200000) DESCRIPTOR: level 2 index: 426 --> 00600000f5400005 (00000000f5400000) DESCRIPTOR: level 2 index: 427 --> 00600000f5600005 (00000000f5600000) DESCRIPTOR: level 2 index: 428 --> 00600000f5800005 (00000000f5800000) DESCRIPTOR: level 2 index: 429 --> 00600000f5a00005 (00000000f5a00000) DESCRIPTOR: level 2 index: 430 --> 00600000f5c00005 (00000000f5c00000) DESCRIPTOR: level 2 index: 431 --> 00600000f5e00005 (00000000f5e00000) DESCRIPTOR: level 2 index: 432 --> 00600000f6000005 (00000000f6000000) DESCRIPTOR: level 2 index: 433 --> 00600000f6200005 (00000000f6200000) DESCRIPTOR: level 2 index: 434 --> 00600000f6400005 (00000000f6400000) DESCRIPTOR: level 2 index: 435 --> 00600000f6600005 (00000000f6600000) DESCRIPTOR: level 2 index: 436 --> 00600000f6800005 (00000000f6800000) DESCRIPTOR: level 2 index: 437 --> 00600000f6a00005 (00000000f6a00000) DESCRIPTOR: level 2 index: 438 --> 00600000f6c00005 (00000000f6c00000) DESCRIPTOR: level 2 index: 439 --> 00600000f6e00005 (00000000f6e00000) DESCRIPTOR: level 2 index: 440 --> 00600000f7000005 (00000000f7000000) DESCRIPTOR: level 2 index: 441 --> 00600000f7200005 (00000000f7200000) DESCRIPTOR: level 2 index: 442 --> 00600000f7400005 (00000000f7400000) DESCRIPTOR: level 2 index: 443 --> 00600000f7600005 (00000000f7600000) DESCRIPTOR: level 2 index: 444 --> 00600000f7800005 (00000000f7800000) DESCRIPTOR: level 2 index: 445 --> 00600000f7a00005 (00000000f7a00000) DESCRIPTOR: level 2 index: 446 --> 00600000f7c00005 (00000000f7c00000) DESCRIPTOR: level 2 index: 447 --> 00600000f7e00005 (00000000f7e00000) DESCRIPTOR: level 2 index: 448 --> 00600000f8000405 (00000000f8000000) DESCRIPTOR: level 2 index: 449 --> 00600000f8200405 (00000000f8200000) DESCRIPTOR: level 2 index: 450 --> 00600000f8400405 (00000000f8400000) DESCRIPTOR: level 2 index: 451 --> 00600000f8600405 (00000000f8600000) DESCRIPTOR: level 2 index: 452 --> 00600000f8800405 (00000000f8800000) DESCRIPTOR: level 2 index: 453 --> 00600000f8a00405 (00000000f8a00000) DESCRIPTOR: level 2 index: 454 --> 00600000f8c00405 (00000000f8c00000) DESCRIPTOR: level 2 index: 455 --> 00600000f8e00405 (00000000f8e00000) DESCRIPTOR: level 2 index: 456 --> 00600000f9000405 (00000000f9000000) DESCRIPTOR: level 2 index: 457 --> 00600000f9200005 (00000000f9200000) DESCRIPTOR: level 2 index: 458 --> 00600000f9400005 (00000000f9400000) DESCRIPTOR: level 2 index: 459 --> 00600000f9600005 (00000000f9600000) DESCRIPTOR: level 2 index: 460 --> 00600000f9800005 (00000000f9800000) DESCRIPTOR: level 2 index: 461 --> 00600000f9a00005 (00000000f9a00000) DESCRIPTOR: level 2 index: 462 --> 00600000f9c00005 (00000000f9c00000) DESCRIPTOR: level 2 index: 463 --> 00600000f9e00005 (00000000f9e00000) DESCRIPTOR: level 2 index: 464 --> 00600000fa000005 (00000000fa000000) DESCRIPTOR: level 2 index: 465 --> 00600000fa200005 (00000000fa200000) DESCRIPTOR: level 2 index: 466 --> 00600000fa400005 (00000000fa400000) DESCRIPTOR: level 2 index: 467 --> 00600000fa600005 (00000000fa600000) DESCRIPTOR: level 2 index: 468 --> 00600000fa800005 (00000000fa800000) DESCRIPTOR: level 2 index: 469 --> 00600000faa00005 (00000000faa00000) DESCRIPTOR: level 2 index: 470 --> 00600000fac00005 (00000000fac00000) DESCRIPTOR: level 2 index: 471 --> 00600000fae00005 (00000000fae00000) DESCRIPTOR: level 2 index: 472 --> 00600000fb000005 (00000000fb000000) DESCRIPTOR: level 2 index: 473 --> 00600000fb200005 (00000000fb200000) DESCRIPTOR: level 2 index: 474 --> 00600000fb400005 (00000000fb400000) DESCRIPTOR: level 2 index: 475 --> 00600000fb600005 (00000000fb600000) DESCRIPTOR: level 2 index: 476 --> 00600000fb800005 (00000000fb800000) DESCRIPTOR: level 2 index: 477 --> 00600000fba00005 (00000000fba00000) DESCRIPTOR: level 2 index: 478 --> 00600000fbc00005 (00000000fbc00000) DESCRIPTOR: level 2 index: 479 --> 00600000fbe00005 (00000000fbe00000) DESCRIPTOR: level 2 index: 480 --> 00600000fc000005 (00000000fc000000) DESCRIPTOR: level 2 index: 481 --> 00600000fc200005 (00000000fc200000) DESCRIPTOR: level 2 index: 482 --> 00600000fc400005 (00000000fc400000) DESCRIPTOR: level 2 index: 483 --> 00600000fc600005 (00000000fc600000) DESCRIPTOR: level 2 index: 484 --> 00600000fc800005 (00000000fc800000) DESCRIPTOR: level 2 index: 485 --> 00600000fca00005 (00000000fca00000) DESCRIPTOR: level 2 index: 486 --> 00600000fcc00005 (00000000fcc00000) DESCRIPTOR: level 2 index: 487 --> 00600000fce00005 (00000000fce00000) DESCRIPTOR: level 2 index: 488 --> 00600000fd000405 (00000000fd000000) DESCRIPTOR: level 2 index: 489 --> 00600000fd200405 (00000000fd200000) DESCRIPTOR: level 2 index: 490 --> 00600000fd400405 (00000000fd400000) DESCRIPTOR: level 2 index: 491 --> 00600000fd600405 (00000000fd600000) DESCRIPTOR: level 2 index: 492 --> 00600000fd800405 (00000000fd800000) DESCRIPTOR: level 2 index: 493 --> 00600000fda00405 (00000000fda00000) DESCRIPTOR: level 2 index: 494 --> 00600000fdc00405 (00000000fdc00000) DESCRIPTOR: level 2 index: 495 --> 00600000fde00405 (00000000fde00000) DESCRIPTOR: level 2 index: 496 --> 00600000fe000405 (00000000fe000000) DESCRIPTOR: level 2 index: 497 --> 00600000fe200405 (00000000fe200000) DESCRIPTOR: level 2 index: 498 --> 00600000fe400405 (00000000fe400000) DESCRIPTOR: level 2 index: 499 --> 00600000fe600405 (00000000fe600000) DESCRIPTOR: level 2 index: 500 --> 00600000fe800405 (00000000fe800000) DESCRIPTOR: level 2 index: 501 --> 00600000fea00405 (00000000fea00000) DESCRIPTOR: level 2 index: 502 --> 00600000fec00405 (00000000fec00000) DESCRIPTOR: level 2 index: 503 --> 00600000fee00405 (00000000fee00000) DESCRIPTOR: level 2 index: 504 --> 00600000ff000405 (00000000ff000000) DESCRIPTOR: level 2 index: 505 --> 00600000ff200405 (00000000ff200000) DESCRIPTOR: level 2 index: 506 --> 00600000ff400405 (00000000ff400000) DESCRIPTOR: level 2 index: 507 --> 00600000ff600405 (00000000ff600000) DESCRIPTOR: level 2 index: 508 --> 00600000ff800405 (00000000ff800000) DESCRIPTOR: level 2 index: 509 --> 00600000ffa00405 (00000000ffa00000) DESCRIPTOR: level 2 index: 510 --> 00600000ffc00405 (00000000ffc00000) DESCRIPTOR: level 2 index: 511 --> 00000000ffe00601 (00000000ffe00000) DESCRIPTOR: level 1 index: 004 --> 0060000100000005 (0000000100000000) DESCRIPTOR: level 1 index: 005 --> 0060000140000005 (0000000140000000) DESCRIPTOR: level 1 index: 006 --> 0060000180000005 (0000000180000000) DESCRIPTOR: level 1 index: 007 --> 00600001c0000005 (00000001c0000000) DESCRIPTOR: level 1 index: 008 --> 0060000200000005 (0000000200000000) DESCRIPTOR: level 1 index: 009 --> 0060000240000005 (0000000240000000) DESCRIPTOR: level 1 index: 010 --> 0060000280000005 (0000000280000000) DESCRIPTOR: level 1 index: 011 --> 00600002c0000005 (00000002c0000000) DESCRIPTOR: level 1 index: 012 --> 0060000300000005 (0000000300000000) DESCRIPTOR: level 1 index: 013 --> 0060000340000005 (0000000340000000) DESCRIPTOR: level 1 index: 014 --> 0060000380000005 (0000000380000000) DESCRIPTOR: level 1 index: 015 --> 00600003c0000005 (00000003c0000000) DESCRIPTOR: level 1 index: 016 --> 0060000400000405 (0000000400000000) DESCRIPTOR: level 1 index: 017 --> 0060000440000405 (0000000440000000) DESCRIPTOR: level 1 index: 018 --> 0060000480000405 (0000000480000000) DESCRIPTOR: level 1 index: 019 --> 00600004c0000405 (00000004c0000000) DESCRIPTOR: level 1 index: 020 --> 0060000500000405 (0000000500000000) DESCRIPTOR: level 1 index: 021 --> 0060000540000405 (0000000540000000) DESCRIPTOR: level 1 index: 022 --> 0060000580000405 (0000000580000000) DESCRIPTOR: level 1 index: 023 --> 00600005c0000405 (00000005c0000000) DESCRIPTOR: level 1 index: 024 --> 0060000600000405 (0000000600000000) DESCRIPTOR: level 1 index: 025 --> 0060000640000405 (0000000640000000) DESCRIPTOR: level 1 index: 026 --> 0060000680000405 (0000000680000000) DESCRIPTOR: level 1 index: 027 --> 00600006c0000405 (00000006c0000000) DESCRIPTOR: level 1 index: 028 --> 0060000700000405 (0000000700000000) DESCRIPTOR: level 1 index: 029 --> 0060000740000405 (0000000740000000) DESCRIPTOR: level 1 index: 030 --> 0060000780000405 (0000000780000000) DESCRIPTOR: level 1 index: 031 --> 00600007c0000405 (00000007c0000000) DESCRIPTOR: level 1 index: 032 --> 0000000800000e01 (0000000800000000) DESCRIPTOR: level 1 index: 033 --> 0000000840000e01 (0000000840000000) DESCRIPTOR: level 1 index: 034 --> 0000000880000e01 (0000000880000000) DESCRIPTOR: level 1 index: 035 --> 00000008c0000e01 (00000008c0000000) DESCRIPTOR: level 1 index: 036 --> 0000000900000e01 (0000000900000000) DESCRIPTOR: level 1 index: 037 --> 0000000940000e01 (0000000940000000) DESCRIPTOR: level 1 index: 038 --> 0000000980000e01 (0000000980000000) DESCRIPTOR: level 1 index: 039 --> 00000009c0000e01 (00000009c0000000) DESCRIPTOR: level 1 index: 040 --> 0000000a00000e01 (0000000a00000000) DESCRIPTOR: level 1 index: 041 --> 0000000a40000e01 (0000000a40000000) DESCRIPTOR: level 1 index: 042 --> 0000000a80000e01 (0000000a80000000) DESCRIPTOR: level 1 index: 043 --> 0000000ac0000e01 (0000000ac0000000) DESCRIPTOR: level 1 index: 044 --> 0000000b00000e01 (0000000b00000000) DESCRIPTOR: level 1 index: 045 --> 0000000b40000e01 (0000000b40000000) DESCRIPTOR: level 1 index: 046 --> 0000000b80000e01 (0000000b80000000) DESCRIPTOR: level 1 index: 047 --> 0000000bc0000e01 (0000000bc0000000) DESCRIPTOR: level 1 index: 048 --> 0000000c00000e01 (0000000c00000000) DESCRIPTOR: level 1 index: 049 --> 0000000c40000e01 (0000000c40000000) DESCRIPTOR: level 1 index: 050 --> 0000000c80000e01 (0000000c80000000) DESCRIPTOR: level 1 index: 051 --> 0000000cc0000e01 (0000000cc0000000) DESCRIPTOR: level 1 index: 052 --> 0000000d00000e01 (0000000d00000000) DESCRIPTOR: level 1 index: 053 --> 0000000d40000e01 (0000000d40000000) DESCRIPTOR: level 1 index: 054 --> 0000000d80000e01 (0000000d80000000) DESCRIPTOR: level 1 index: 055 --> 0000000dc0000e01 (0000000dc0000000) DESCRIPTOR: level 1 index: 056 --> 0000000e00000e01 (0000000e00000000) DESCRIPTOR: level 1 index: 057 --> 0000000e40000e01 (0000000e40000000) DESCRIPTOR: level 1 index: 058 --> 0000000e80000e01 (0000000e80000000) DESCRIPTOR: level 1 index: 059 --> 0000000ec0000e01 (0000000ec0000000) DESCRIPTOR: level 1 index: 060 --> 0000000f00000e01 (0000000f00000000) DESCRIPTOR: level 1 index: 061 --> 0000000f40000e01 (0000000f40000000) DESCRIPTOR: level 1 index: 062 --> 0000000f80000e01 (0000000f80000000) DESCRIPTOR: level 1 index: 063 --> 0000000fc0000e01 (0000000fc0000000)
Can someone help me?
Best regards,
Ciro
Did you enable SMP mode:
/*Enable hardware coherency between cores*/ mrs x0, S3_1_c15_c2_1 //Read EL1 CPU Extended Control Register orr x0, x0,#(1 << 6) //Set the SMPEN bit msr S3_1_c15_c2_1, x0 //Write EL1 CPU Extended Control Register isb
Are you executing the spin-lock in EL2 or EL1? You mentioned EL2 in your post, but the registers you quoted are for EL1.
Yes, I enabled this mode. Anyway I found the problem. I forgot to set the shareability attribute in the pagetable.Thank you for the answer.
