******************************************************************************/ /*****************************************************************************/ /** * @file translation_table.s * * @addtogroup a53_32_boot_code * @{ * <h2> translation_table.S </h2> * translation_table.S contains a static page table required by MMU for * cortex-A53. This translation table is flat mapped (input address = output * address) with default memory attributes defined for zynq ultrascale+ * architecture. It utilizes short descriptor translation table format with each * section defining 1MB of memory. * The overview of translation table memory attributes is described below. * *| | Memory Range | Definition in Translation Table | *|-----------------|-------------------------|---------------------------------| *| DDR | 0x00000000 - 0x7FFFFFFF | Normal write-back Cacheable | *| PL | 0x80000000 - 0xBFFFFFFF | Strongly Ordered | *| QSPI, lower PCIe| 0xC0000000 - 0xEFFFFFFF | Device Memory | *| Reserved | 0xF0000000 - 0xF7FFFFFF | Unassigned | *| STM Coresight | 0xF8000000 - 0xF8FFFFFF | Device Memory | *| GIC | 0xF9000000 - 0xF90FFFFF | Device memory | *| Reserved | 0xF9100000 - 0xFCFFFFFF | Unassigned | *| FPS, LPS slaves | 0xFD000000 - 0xFFBFFFFF | Device memory | *| CSU, PMU | 0xFFC00000 - 0xFFDFFFFF | Device Memory | *| TCM, OCM | 0xFFE00000 - 0xFFFFFFFF | Normal write-back cacheable | * * @note * * For DDR in region 0x00000000 - 0x7FFFFFFF, a system where DDR is less than * 2GB, region after DDR and before PL is marked as undefined/reserved in * translation table. In region 0xFFC00000 - 0xFFDFFFFF, it contains CSU * and PMU memory which are marked as Device since it is less than 1MB and * falls in a region with device memory. * * <pre> * MODIFICATION HISTORY: * * Ver Who Date Changes * ----- ---- -------- --------------------------------------------------- * 5.2 pkp 28/05/15 First release * 5.4 pkp 18/12/15 Updated the address map according to proper address map * 6.0 mus 20/07/16 Added warning for ddrless HW design CR-954977 * </pre> * * ******************************************************************************/ #include "xparameters.h" .globl MMUTable .section .mmu_tbl,"a" MMUTable: /* Each table entry occupies one 32-bit word and there are * 4096 entries, so the entire table takes up 16KB. * Each entry covers a 1MB section. */ .set SECT, 0 #ifdef XPAR_PSU_DDR_0_S_AXI_BASEADDR .set DDR_START, XPAR_PSU_DDR_0_S_AXI_BASEADDR .set DDR_END, XPAR_PSU_DDR_0_S_AXI_HIGHADDR .set DDR_SIZE, (DDR_END - DDR_START)+1 .if DDR_SIZE > 0x80000000 /* If DDR size is larger than 2GB, truncate to 2GB */ .set DDR_REG, 0x800 .else .set DDR_REG, DDR_SIZE/0x100000 .endif #else .set DDR_REG, 0 #warning "There's no DDR in the HW design. MMU translation table marks 2 GB DDR address space as undefined" #endif .set UNDEF_REG, 0x800 - DDR_REG .rept DDR_REG /* DDR Cacheable */ .word SECT + 0x15de6 /* S=b1 TEX=b101 AP=b11, Domain=b1111, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept UNDEF_REG /* unassigned/reserved */ /* Generates a translation fault if accessed */ .word SECT + 0x0 /* S=b0 TEX=b000 AP=b00, Domain=b0, C=b0, B=b0 */ .set SECT, SECT+0x100000 .endr .rept 0x0200 /* 0x80000000 - 0x9fffffff (FPGA slave0) */ .word SECT + 0xc02 /* S=b0 TEX=b000 AP=b11, Domain=b0, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept 0x0200 /* 0xA0000000 - 0xbfffffff (FPGA slave1) */ .word SECT + 0xc02 /* S=b0 TEX=b000 AP=b11, Domain=b0, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept 0x0200 /* 0xc0000000 - 0xdfffffff (OSPI IOU)*/ .word SECT + 0xc06 /* S=b0 TEX=b000 AP=b11, Domain=b0, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept 0x0100 /* 0xe0000000 - 0xefffffff (Lower PCIe)*/ .word SECT + 0xc06 /* S=b0 TEX=b000 AP=b11, Domain=b0, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept 0x80 /* 0xf0000000 - 0xf7ffffff (unassigned/reserved). * Generates a translation fault if accessed */ .word SECT + 0x0 /* S=b0 TEX=b000 AP=b00, Domain=b0, C=b0, B=b0 */ .set SECT, SECT+0x100000 .endr .rept 0x10 /* 0xf8000000 - 0xf8ffffff (STM Coresight) */ .word SECT + 0xc06 /* S=b0 TEX=b000 AP=b11, Domain=b0, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept 0x1 /* 0xf9000000 - 0xf90fffff (RPU_A53_GIC) */ .word SECT + 0xc06 /* S=b0 TEX=b000 AP=b11, Domain=b0, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept 0x3f /* 0xf9100000 - 0xfcffffff (reserved).*/ .word SECT + 0x0 /* S=b0 TEX=b000 AP=b00, Domain=b0, C=b0, B=b0 */ .set SECT, SECT+0x100000 .endr .rept 0x10 /* 0xfd000000 - 0xfdffffff (FPS Slaves) */ .word SECT + 0xc06 /* S=b0 TEX=b000 AP=b11, Domain=b0, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept 0x1C /* 0xfe0000000 - 0xfeffffff (LPS Slaves) */ .word SECT + 0xc06 /* S=b0 TEX=b000 AP=b11, Domain=b0, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept 0x2 /* 0xffc000000 - 0xffdfffff (CSU and PMU) */ .word SECT + 0xc06 /* S=b0 TEX=b000 AP=b11, Domain=b0, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .rept 0x02 /* 0xffe00000 - 0xffffffff (TCM and OCM Cacheable) */ .word SECT + 0x15de6 /* S=b1 TEX=b101 AP=b11, Domain=b1111, C=b0, B=b1 */ .set SECT, SECT+0x100000 .endr .end /** * @} End of "addtogroup a53_32_boot_code". */
thank you.
Difficult to explain Did you read the respective manuals. Maybe ask concrete questions.
