Problem in calling the function in ISR
I'm using LPC2148 controller and interfacing accelerometer sensor, I need to enable this
sensor all the time and with the counter set in the ISR it should come out of the loop, below is
the code.
#include "adc.h"
#include "lcd.h"
#include "lcd1.h"
#include "systemInit.h"
#include "delay.h"
#include <stdio.h>
#include "string.h"
//#include "uart.h"
#include "config.h"
#include "stdlib.h"
#define BUZZER (1 << 25)
#define BUZZER_DIR IO1DIR
#define BUZZER_SET IO1SET
#define BUZZER_CLR IO1CLR
#define TIMER_TICK_1_MS (59999) /* VPB at 60 MHz clock */
static unsigned int ms_count;
void delay2(int count);
void TimerInit(void);
unsigned char buf[16] = {0};
int adcValue;//x
int adcValue1;//y
int adcValue2;//z
int adcValue3;//for X difference
int adcValue4;//for Y difference
int adcValue5;//for Z difference
int delta_x;
int delta_y;
int delta_z;
int thx_x = 10;
int thx_y = 10;
int thx_z = 10;
int a,b;
float temp;
unsigned int sensor_detect();
void delayMS(unsigned int milliseconds)
 /*Assuming that PLL0 has been setup with CCLK = 60Mhz and PCLK also = 60Mhz.*/
 T0CTCR = 0;
 T0PR = 60000; //60000 clock cycles = 1 mS @ 60Mhz
 T0TCR = 0x02; //Reset Timer
 T0TC = 0;
 T0TCR = 0x01; //Enable timer
 while(T0TC < milliseconds); //wait until timer counter reaches the desired delay
 T0TCR = 0x00; //Disable timer
void Timer_ISR(void) __irq
ms_count++;
///* Count increments for every 1MSec */
if(ms_count == 10)
sensor_detect();
ms_count = 0;
T1IR = 0x01;
VICVectAddr = 0x00;
 T1TCR = 0x00; /* ensure timer 1 is off */
 /* set timer counter and prescale counter */
 T1TC = 0x0;
 T1PC = 0x0;
 /* set prescale and match values to give 1 ms "tick" */
 T1PR = 0x0;
 T1MR0 = TIMER_TICK_1_MS;
 /* set control to interrupt on MR0 match, and reset to 0 (i.e. "tick") */
 T1MCR = 0x3;
 /* vector TIMER 1 as mid-level priority and enabled */
 VICVectCntl11 = 0x25;
 /* vector TIMER 1 interrupt address */
 VICVectAddr11 = (unsigned int) Timer_ISR;
 /* enable TIMER 1 in VIC */
 VICIntEnable = 0x0020;
 /* go start timer 1... */
 T1TCR = 0x1;
int main()
  ADC_Init();
  init_lcd();
  TimerInit();     //Timer initialisation
  lcd_clear();        // clear display
while(1)
 sprintf((char *)buf, "a:%d ",a);//need to print the sensor values 0 and 1 here
 lcd_putstring(0, (char *)buf);
    ADC_Init();
        adcValue =  ADC_GetAdcValue(AD0_1);//x // Read the ADC value of channel zero where the temperature sensor(LM35) is connected
        adcValue1 = ADC_GetAdcValue(AD0_2);//y
    adcValue2 = ADC_GetAdcValue(AD0_4);//z
    sprintf((char *)buf," X=%4d",adcValue-804);
//      lcd_putstring(0, (char *)buf);
    sprintf((char *)buf,"   Y=%4d",adcValue1-813);
    sprintf((char *)buf,"       Z=%4d",adcValue2-601);
//      lcd_putstring(1, (char *)buf);
    delayMS(50);
    adcValue3 = ADC_GetAdcValue(AD0_1); //X AXIS
    delta_x = adcValue - adcValue3;
    if (delta_x > thx_x)
     BUZZER_DIR |= BUZZER;
     BUZZER_SET |= BUZZER;
    a=1;//need to print this value in main function
    adcValue4 = ADC_GetAdcValue(AD0_2); //Y AXIS
    delta_y = adcValue1 - adcValue4;
    if (delta_y > thx_y)
     a=2;//need to print this value in main function
    adcValue5 = ADC_GetAdcValue(AD0_4); //Z AXIS
    delta_z = adcValue2 - adcValue5;
    if (delta_z > thx_z)
    a=3;//need to print this value in main function
return a;
Presently only a=0 is printing on LCD, sensor function part is not working, if sensor function is called in the main() it works fine and displays detected values on LCD. Any suggestions will be of great help.
Regards,
Aakansha
