#include<lpc214x.h>
int main()
PINSEL0=0x00000002; // P0.0 to P0.15 pins of PORT0 as GPIO
PINSEL1=0x00000000; // P0.21 Pin of PORT0 as PWM
PINSEL2=0x00000000; // P1.16 to P1.31 pins of PORT1 as GPIO
/*Configure the PLL block and set the CCLK and PCLK at 60 MHz */
//PLL0CON=0x01;
//PLL0CFG=0x25;
//PLL0FEED=0xaa;
//PLL0FEED=0x55;
//while (! (PLL0STAT & 0x00000400));
//PLL0CON=0x03;
//VPBDIV=0x01;
/* Setup and initialize the PWM block */
PWMPCR=0x00; // Single Edge PWM Mode
PWMPR=0x00; // Resolution of PWM is set at 1 mS
PWMMR0=1000; // Period of PWM is 10 mS
PWMMR1=100; // Pulse width of PWM5 is 1 mS
PWMMCR= (1<<1); // PWMTC is reset on match with PWMMR0
PWMLER= (1<<1)| (1<<0); // Update Match Registers PWMMR0 and PWMMR1
PWMPCR= (1<<9); // Enable PWM1 output
PWMTCR= (1<<1); // Reset PWM TC and PWM PR
PWMTCR= (1<<0)| (1<<3); // Enable PWM Timer Counters and PWM Mode
while (1)
if (! ((IO0PIN) & (1<<15))) // Check for P0.15
PWMMR1 = 100;
PWMLER = (1<<1); //Update Latch Enable bit for PWMMR1
else if ( ! ((IO0PIN) & (1<<16))) // Check P0.16
PWMMR1 = 200;
PWMLER = (1<<1);
else if (! ((IO1PIN) & (1<<16)) ) // Check for P1.16
PWMMR5 = 400;
else if (! ((IO1PIN) & (1<<17))) // Check for P1.17
PWMMR5 = 800;
//return 0;
I am trying to generate PWM output on pin 19 or using PWM1.it works on logic analyzer but doesn't run on hardware.LED brightness is no changing nor LED lighting.Pls can I get a help.
View all questions in Classic processors forum
