armv5TE
HI,
I am using an armv5TE (mv78100)I wonder  if I need to implement memory barriers in this architecture,(some people say not needed)
reason for my question is that I am facing system total freeze(now and then) and I suspect the system(freebsd) beeing on the idle loop!
  • Architecturally you need to include barriers where ever the architecture says you need to include barriers; anything else is making assumptions about the CPU micro-architecture which may work on some CPUs and not on others.
    Many of the early ARMv5TE cores developed by ARM, such as the ARM926, were relatively simple micro-architectures so you could "get away with it" if you omitted certain barriers, but this is certainly not recommended practice and not likely to be portable. There are a number of alternative ARMv5TE implementations from ARM architecture licensees which have totally different microarchitectures, such as the Sheeva family CPU in your SoC,  which may include other optimizations and therefore be stricter in terms of the need to have barriers present.
    In short: the only way to write portable code is to include all of the barriers that the architecture requires.
    HTH,
    Pete
    HTH,
    Pete
