in arm7tdmi, suppose instruction is being executed and at same time FIQ and IRQ both occur at same time.now according to priority FIQ will be handled then IRQ but my question is that how it will handled IRQ after return from FIQ
i means what will be process done at return of FIQ and how control will be transferred to IRQ handler after return statement of FIQ handler ?
example :
address => instruction
0x00000100 : MOV R0,R1
0x00000104 : MOV R0,R1
==> 0x00000108 : MOV R0,R1 ; suppose this is instruction being executed and FIQ and IRQ are raised at same time
0x00000110 : MOV R0,R1
0x00000114 : MOV R0,R1
0x00000118 : MOV R0,R1
Thanks for your question.
I believe that the IRQ vector will be fetched immediately on completion of the return statement at the end of the FIQ handler. Are you trying to resolve a particular timing issue?
Hope this helps.
Chris
hello,
thanks for replay,
suppose now instructions are being executed in user mode,suppos at address : 0x00000108 some instruction is being executed and while it is being executed, IRQ and FIQ are raised at same time so according to priority FIQ will be handled first and the address of next instruction at 0x0000110 is stored in ti R14_FIQ and cpsr to spsr_FIQ. so at the return from FIQ, r14_FIQ will be stored pc and spsr_FIQ to cpsr,this is what generaly happens,but suppose IRQ raised at same time FIQ raised then after FIQ handeled ,irq is to be handeled so what would be steps to enter to IRQ handeler after return statement of FIQ handeler,(i.e will it go first to user mode and execute one institution at 0x00000110 as per our example or from FIQ handler(FIQ mode) it will go to irq handler(IRQ mode) .
No, it won't go to User mode and execute an introduction before executing the IRQ vector. The restored LR and CPSR will be copied immediately to LR_irq and SPSR_Irq and the IRQ vector will be executed before any further instructions from the interrupted sequence are executed.
Hope this help.
so what i understood is that on return instruction of FIQ handler, R14_FIQ and SPSR_FIQ will be copied to R14_IRQ and SPSR_IRQ respectively and and directly IRQ handler will start execution after completion of FIQ handler.
and at the return instruction in IRQ handler R14_IRQ and SPSR_IRQ will be copied to PC and CPSR and control will go to interrupted mode and will start execution next instruction from the instruction which was interrupted in interrupted mode.
correct me if i am wrong.
thank you.
That's now quite what I said!
During the return from the FIQ, LR_fiq and SPSR_fiq will be copied to LR and CPSR. Once that return is complete, execution of the IRQ vector will start and LR/CPSR will be copied to LR_irq and SPSR_irq. So, no direct copy, the values will go via the User mode registers.
so it will go to user mode or intercepted mode before going to IRQ mode
but you said
LR_FIQ to LR_ interrupted_mode and SPSR_FIQ to CPSR
but i think LR_FIQ should be transferred to PC instead of LR_ interrupted_mode
and after that no further instruction will be executed in interrupted mode and PC will be copied to LR_IRQ and CPSR will be copied to SPSR_IRQ while going to IRQ handler (IRQ mode).
so correct me if i am wrong.
the question is that LR_FIQ should be copied to PC not to LR_of_interrupted_mode so did i assume right or wrong?
Yes, sorry, my typo. Apologies for any confusion. I meant to say:
>During the return from the FIQ, LR_fiq and SPSR_fiq will be copied to PC and CPSR. Once that return is complete, execution of the IRQ vector
>will start and PC/CPSR will be copied to LR_irq and SPSR_irq. So, no direct copy, the values will go via the User mode (or whichever mode was
>interrupted) registers.
Sorry! I hope it's clear now.
I am still interested to know what problem you are trying to solve which needs this kind of detail about exception sequences...
thank you very much for solving my problem
and sorry for asking you same thing again and again but i wanted to be
quite sure.
actually i am firmware engineer and i have interest in ARM architecture so
i want to learn it literally and then i want to develop my own RTOS based
on ARM platform.so i need clear picture at ARM isa and ARM processor level
and how it works.
it is just that i am crazy about ARM.
again thank you,
nirav
I am glad we got that clarified.
Also glad to hear of your interest in ARM. I would recommend, though, that you consider developing for a more modern processor tan ARM7TDMI. As far as we are concerned, that is very old technology these days and we would recommend using a more modern processor such as Cortex-M3 (for microcontrollers) or one of the Cortex-A series (for application processors).
Do let us know if there is anything else we can help with.
Best wishes
thank you sir,
so as you know i will have to start development form scratch with assembly and c langugae so can you suggest me any cortex-A sires processor development board with which i can get full software tool support and debugging and emulation support at very low level programming.
some known development boards are there but those are good for application programming on top of some kernel but while developing rots i need to do bare-metal coding and need good support of software and debugging and emulation
The Raspberry Pi Model B uses a quad core Cortex-A7 processor. Tools availability is excellent and bare-metal development is well supported and there is a lot of literature about this online.
Though I don't have a RasPi myself, I second chrisshore's suggestion. The Raspberry Pi is an excellent platform, which allows you to start from scratch or develop parts of your system under Linux and when you've finished enough components, you can put them together in a 'stand-alone' O/S.
In addition to the above, you might benefit from getting a WD PiDrive, which was developed specifically for the Raspberry Pi. -It's no coincidence that it's 314 GB either.
In case your development system is a PC, you could attach the PiDrive there, then move the drive to the Raspberry Pi for booting (or testing modules).
View all questions in Classic processors forum
