Hello Community,
I have a question regarding the STMIA instruction in an ARM926EJ-S.
We build a SOC with this core and one of our own modules connected to the DATA-AHB has a bug.
One workaround for this bug is to access four adjacent registers (e.g. 0xB0000050, 0xB0000054, 0xB0000058 and 0xB000005C) of this module with a 32bit wide four beat burst.
(The module must see an address change from 0xB0000050 to 0xB0000054 immediatly after the access to 0xB0000050 and normally a four beat burst to 0xB0000050 should do this.)
Is there a possibility that the STMIA in the code example below is executed as four single NONSEQ accesses from the ARM926EJ-S instead as a four beat burst with HTRANS = NONSEQ, SEQ, SEQ , SEQ?
LDR r0, =0xB0000050
LDR r1, =0x12345678
LDR r2, =0x00000000
LDR r3, =0x00000000
LDR r4, =0x00000000
STMIA r0!, {r1 – r4}
Is there a difference between the code above and the code below regarding the possibility that the STMIA is executed as four single accesses?
LDR r12, =0x00000000
STMIA r0!, {r1 – r3, r12}
Every help welcome.
Thank you.
Best regards
Daniel
View all questions in Classic processors forum
