Break point at SWI handler
Hi everyone,
I'm using Jlink with openocd to debug ARM926EJ-S and encountered problem when executing SWI command.
Even though I don't set a break point at SWI handler but the CPU breaks at SWI handler automatically. How to remove the break point and make the CPU run continuously after every SWI command ?
Thank you very much.
  • Oh I know the reason,
    OpenOCD manual says that :
    Command: arm semihosting
    [enable|disable]
    Display status of semihosting, after optionally changing that status.
    Semihosting allows for code executing on an ARM target to use the I/O facilities on the host computer i.e. the system where OpenOCD is running. The target application must be linked against a library implementing the ARM semihosting convention that forwards operation requests by using a special SVC instruction that is trapped at the Supervisor Call vector by OpenOCD.
    So run command arm semihosting disable to solve the problem.
    [enable|disable]
