ARM1136: why the mismatch between cache stalls and cache misses ??
Something weird when I count both Instruction Cache Miss event and event 0x1 (viz. “Stall because instruction buffer cannot deliver an instruction. This could indicate an Instruction Cache miss or an Instruction MicroTLB miss. This event occurs every cycle in which the condition is present”). If I disable the branch prediction, the stall count goes up dramatically (from 171 to 434 stalls) but the cache misses do not change so much (only from 12 to 13 misses).
ps: I count the Micro TLB misses too, and it always shows to be 0, so it should not be the cause of stalls.
Anyone could help me figure out why ?
Thanks a lot!!
PS: it has been confirmed from the technical manual that the event 0x0 count the L1 cache miss only. Plus, it states that a mis-predicted branch will cause event 0x1 to increment by 1. But the mismatch still exists:the stall count goes up far more than the cache miss count.
Is there anyone who could help me explain this ?
