I am new to arm assembly, i'm trying to print integer to screen instead of their ASCII representation of that number. Below is the code which i'm trying with instead of printing 99 i'm getting 'c'
.global _start .text _start: @ write to num variable _write: mov r8, #99 ldr r9, =num str r8, [r9] @read from num variable and print to screen _read: mov r7, #4 @ syscall mov r0, #1 @ std output ldr r1, =num @ starting address mov r2, #2 @ number of character to print swi 0 @ interrupt _end: mov r7, #1 swi 0 .data num: .word 0
I have checked online resources which has numerous examples of printing strings but not numbers.
[root@alarmpi]# make as -o num.o num.s ld - num num.o [root@alarmpi ]# ./num c
Kindly let me know how to output numbers using ARM assembly (possibly without using C libraries).
Thank You.
Martin Weidmann Thank you. I will check it out.
I think you'll need to write yourself a function to convert into ascii, then pass the result to semihosting call. For reference, here is a list of the available semihosting calls:
developer.arm.com/.../sys_writec-0x03
View all questions in Classic processors forum
