how to utilize interrupts in arm9 processors..? what is residing inside ISR..?
Thanks for your reply.
Just to be clear, the __irq keyword will indeed cause the compiler to output object code which can be installed as an IRQ handler (it will modify the rules for saving/restoring registers and change the return address, for instance) but it will not install the function in the vector table. You still need to do that yourself...
Chris
