Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Announcements
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Pelion IoT Platform
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
Community Help
More
Cancel
Developer Community
IP Products
Processors
Jump...
Cancel
Processors
Classic processors forum
ARM7TDMI: SUBS vs SUB + CMP
Blogs
Forums
Videos & Files
Help
Jump...
Cancel
New
State
Accepted Answer
+1
person also asked this
people also asked this
Replies
Subscribers
2 subscribers
Views
Users
0 members are here
Arm7
Related
Offline
Greger Greger
over 7 years ago
Note: This was originally posted on 2nd April 2009 at
http://forums.arm.com
I have a question regarding the SUBS instruction and how it compares to SUB and CMP (due to unexpected behavior in a C-program).
The original C-code goes like this (all variables are 32 bit signed integers):
t = a*b - c*c;
if (t > 0) d = t;
In a particular case (a = 0x80, b = 0x106DCD9, c = 0x4E352501) I get an overflow in a*b as well as in the subtraction. What is puzzling to me is that there's a difference between the the following two assembler versions in a certain simulated environment - and I'm trying to figure out if this is expected or a bug in the simulator:
MUL temp1, c, c
MUL temp2, a, b
SUBS t, temp2, temp1
MOVGT d, t
and
MUL temp1, c, c
MUL temp2, a, b
SUB t, temp2, temp1
CMP t, #0
MOVGT d, t
(These are genereated depending on different compiler settings.)
Any help is greatly appreciated!
Greger
Top replies
Offline
Peter Harris
over 7 years ago
+1
verified
Note: This was originally posted on 6th April 2009 at http://forums.arm.com I'd highly recommend the ARM System Developer's Guide ( http://www.arm.com/documentation/books/4975.html ) - it covers lots...
0
Offline
Greger Greger
over 7 years ago
Note: This was originally posted on 3rd April 2009 at
Thank you for your answers!
I realize I gave the wrong numbers. The calculation in question (indeed, the root cause is poor algorithm design) is
t = 0x80 * 0x106DCD9 - 0x8D7F * 0x8D7F
=> t = 0x836E6C80 - 0x4E352501 (=0x3539477F)
(a = 0x80, b = 0x106DCD9, c = 0x8DF, a*b = 0x836E6C80, c*c = 0x4E352501)
So, if I understand you right we should have
MUL temp1, c, c => no overflow flag, no negative flag (this is in bounds)
MUL temp2, a, b => negative flag, no overflow flag (but shouldn't overflow be set since it's a signed multiply?)
SUBS t, temp2, temp1 => no negative flag, overflow flag (underflow)
MOVGT d, t => MOV is not executed
and
SUB t, temp2, temp1
CMP t, #0 => 0x3539477F - 0 => no negative flag, no overflow overflow flag
MOVGT d, t => MOV is executed
OK. Then it is really not a problem with the simulator but that the optimizer takes a legal short cut due to a poorly designed algorithm (which overflows). "Good."
Just a follow-up question here, shouldn't the negative flag be set in the SUBS? I mean we do subtract a positive number from a negative number.
Thanks again!
Greger
Cancel
Up
0
Down
Accept answer
Cancel
0
Offline
Greger Greger
over 7 years ago
Note: This was originally posted on 7th April 2009 at
The ARM we're working with is ARM7TDMI (Texas Instruments TMS470). Actually, we work with several different embedded controllers but the TI compiler was the only one taking this particular, unfortunately "legal", shortcut :-) But I'll definitely read up on the ARM family!
Cancel
Up
0
Down
Accept answer
Cancel
0
Offline
Greger Greger
over 7 years ago
Thank you very much for all your answers! I also realize I need to find myself a good book on this... :-)
Greger
Cancel
Up
0
Down
Accept answer
Cancel
0
Offline
Peter Harris
over 7 years ago
That looks like a bug in your simulator - although not because the behavior is different.
The reason...
GT is defined as executing if "Z == 0 and N == V" in the CPSR flag bits.
In your example:
temp1 = F3C3 4A01 (overflowed)
temp2 = 836E6C80
t = temp2 - temp1 (underflowed)
In the SUBS case the SUBS instruction will perform (836E6C80 - F3C3 4A01 = 8FAB227F) which will set Nzcv in the CPSR (Negative, non-zero, no carry, no overflow) - this means the final MOVGT won't execute. No carry for a subtract indicates underflow.
In the CMP case the CMP instruction will perform (8FAB227F - 0) which will set NzCv in the CPSR (Negative, non-zero, Carry, no overflow) - which should also mean that the final MOVGT won't execute. Carry for a subtract indicates no underflow occured.
It is worth noting that the CPSR flags are different for these two cases, so some condition codes for the final MOV may validly generate different behavior for the two cases. Compilers are not designed to cope with under/overflow - so this is allowed by the C spec =)
Cancel
Up
0
Down
Accept answer
Cancel
0
Offline
Peter Harris
over 7 years ago
The ARM core generally has no notion of signed and unsigned instructions (for general data processing anyway - signed and unsigned multiply and saturating DSP instructions exist) - that's a compiler issue to generate appropriate instructions which fit 2's complement maths, the 'N'egative bit is simply bit 31 of the result register.
Also - you mention flag setting in your multiplication instructions - on ARM the flags are only set for instructions with the 'S' postfix (there are notable exceptions such as CMP and CMPN which implicitly set flags). So SUBS sets the flags, SUB doesn't. In your case the MUL will not set any flags at all because it isn't a MULS.
Cancel
Up
0
Down
Accept answer
Cancel
0
Offline
Simon Craske
over 7 years ago
To merge the comparison into the SUBS flag setting would require the ability to perform a condition check for N clear and Z clear, i.e a positive non-zero value; however, no such condition check exists.
The closest is GT, with V clear, i.e. Z clear and N==V.
Whether or not this is a compiler bug is a different question; the compiler choosing GT rathen than NE, indicates that "t" is a "signed int", and this may be why this apparently erroneous behaviour is legal -- the C standard has a number of caveats with respect to arithmetic operations exceeding the precision of "signed" integer types and allowing implemenation defined results.
hth
s.
Cancel
Up
0
Down
Accept answer
Cancel
+1
Offline
Peter Harris
over 7 years ago
) - it covers lots of useful stuff from algorithms to operating system techniques.
It is slightly out of date now - it mostly covers ARMv5T(E) which is ARM, Thumb and ARM 'E' DSP instructions. This is all relevant to newer processors too - but if you expect to be working on ARM11 (ARMv6) or any of the Cortex (ARMv7)processors, expect minor differences and additions (such as the Thumb2 instruction set).
Cancel
Up
+1
Down
Reject answer
Cancel
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Answered
Program Counter, Stack Pointer and Link Register Status During an Interrupt Service in ARM based Processors
+1
3446
views
2
replies
Latest
over 1 year ago
by
Aman007kc
Answered
ARM Assembly how to print numbers instead of their ascii representation of that number
+1
Armv6
Arm Assembly Language (ASM)
5851
views
2
replies
Latest
over 1 year ago
by
Kanan Jarrus
Not Answered
Why there is no translation tables concatenation for stage 1 of VA translation?
0
1485
views
0
replies
Started
over 1 year ago
by
Uzi Shvadron
Answered
Arm Cortex-A8 program flow prediction
+1
Armv7-A
Cache
Out-of-order Execution
Cortex-A
1777
views
1
reply
Latest
over 1 year ago
by
Andy Neil
Suggested Answer
Shifted binary generated by arm-none-eabi-objcopy
0
GCC
Cortex-A
Cortex-M
Baremetal
4928
views
8
replies
Latest
over 1 year ago
by
en2senpai
View all questions in Classic processors forum
