Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Announcements
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
Community Help
More
Cancel
Developer Community
IP Products
Processors
Jump...
Cancel
Processors
Classic processors forum
About TRACE32, DMA, and CACHE
Blogs
Forums
Videos & Files
Help
Jump...
Cancel
New
State
Accepted Answer
+1
person also asked this
people also asked this
Replies
Subscribers
2 subscribers
Views
Users
0 members are here
Trace
Arm9
Debugging
Related
Offline
guestposter guestposter
over 7 years ago
Note: This was originally posted on 17th March 2009 at
http://forums.arm.com
Hi ALL:
i have some questions about the TRACE32, DMA, and CPU CACHE.
i am now using the OMAP331 MPU, which contains an ARM926ejs core, and also has DMA controller.
i use DMA to read data from peripheral NAND flash to SDRAM(address from 0x11700000). and the result is as below:
(1). use TRACE32 to load program into sdram and run it, call function to start DMA to read data from nand flash to SDRAM, the read data is stored from address 0x11700000. after DMA read finish, i use "d.dump 0x11700000" to see the content of sdram, and everything is ok. the content of 0x11700000 is the real content inside the nand flash.
(2). if i first use "d.dump 0x11700000" command to show the content of sdram, and then start DMA transfer, then after DMA finish, the content of sdram does not change, i guess that it is because of the cache of cpu, so i flush the cache, then content is updated immediatly on trace32 .
my question is : when trace32 asks arm9 to give content of address(0x11700000), how does arm9 answer trace32 ?
(3). first use "d.dump 0x11700000" command to show the content of sdram. and then start DMA transfer. after DMA finish, flush cache, so the content of sdram is updated. then execute printf() instruction in program to print content of address 0x11700000 to hyper terminal, we assume that the content shown on pc is 0x12345678. then i use trace32 to change the value of 0x11700000 from 0x12345678 to 0x0. and then start DMA transfer once again, i means to read the same blocks from nand flash to sdram 0x11700000. after DMA finish, flush cache. but the content of 0x11700000 is not updated, it is still 0x0!!! it should be 0x12345678. so i think it is because of the instruction "printf()" influences the cache about address 0x11700000, but who can give me more precise explanation about this result?
(4). first use "d.dump 0x11700000" command to show the content of sdram. and then start DMA transfer. after DMA finish, flush cache, so the content of sdram is updated. then execute printf() instruction in program to print content of address 0x11700000 to hyper terminal, we assume that the content shown on pc is 0x12345678.
then flash cache again
. then i use trace32 to change the value of 0x11700000 from 0x12345678 to 0x0. and then start DMA transfer once again, i means to read the same blocks from nand flash to sdram 0x11700000. after DMA finish, flush cache. the content of 0x11700000 changed from 0x0 to 0x12345678. it is right.
here i flush cpu cache for three times. between the first two actions is a printf() instruction. so i think that this instruction influences the cache about address 0x11700000,
at last, many questions in my mide:
1. does dma transfer using cpu cache?
2. how does cpu answer trance32 to give content of address?
3. when using trace32 to change content of address, what does cpu do in the same time? will it updata its cache also?
4. after dma transfer, the content of some address will be changed, will cpu check these address and update the cache?
Top replies
Offline
Simon Craske
over 7 years ago
+1
verified
Note: This was originally posted on 21st March 2009 at http://forums.arm.com I'm not familiar with Trace32 or OMAP331, however, assuming Trace32 is just using the ARM926's scan-based debug, and that the...
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Answered
ARM926EJ-S, Can a STMIA result in four single accesses instead of a burst?
+1
32-bit
Arm9
6037
views
5
replies
Latest
over 4 years ago
by
Chris Shore
Answered
in arm7tdmi, when FIQ and RIQ occures at same time so how both are executed sequentially,first FIQ and thenIRQ?
0
Arm7
Cortex-M3
Cortex-A
Cortex-A7
Cortex-M
12717
views
12
replies
Latest
over 4 years ago
by
Jens Bauer
Answered
State of link register on an interrupt from Thumb (ARM7TDMI).
+1
Arm7
Thumb
2392
views
1
reply
Latest
over 4 years ago
by
Yasuhiko Koumoto
Answered
Program Execution Cycles
+1
Raspberry Pi
Arm11
4108
views
3
replies
Latest
over 4 years ago
by
Chris Shore
Answered
PMU (Performance monitor Unit)
0
Raspberry Pi
Arm11
Performance Monitor Unit (PMU)
5873
views
3
replies
Latest
over 4 years ago
by
Yasuhiko Koumoto
View all questions in Classic processors forum
