Hello, I started to tinker with the most basic Cortex-M0 from the DesignStart.I am using Modelsim Student Edition, which run only on Windows (or Linux through Wine).I tried to start with Linux to see if at least the "make" commands are working. Problem is, when I end up in the folder "systems\cortex_m0_mcu\rtl_sim\" where I should use the makefile, I get errors which I think are trivial, but I am completely new on complex Verilog designs.
The error is shown here in MinGw, but is the same on a fully setup Linux machine:
I am able, despite this, to load in Modelsim the FPGA testbench, compiling it and running. But without the initial setup (due to the previous error) I am not able to run the "hello" program or whatever I need to issue to the testbench.
Any suggestion? I think I am doing something really naive.
Thanks,
Enrico
Maybe the student edition doesn't support the '-lint' option. You can edit the makefile (line 172) to remove this option. So long as you can prepare image.hex with the test code, there shouldn't be anything else important going on in the makefile. Another possibility might be that the vlog command being executed is something other than the simulator, but that would be odd.
Looking at the spec for the student edition, the design may exceed the 10,000 lines of executable code limitation.
You guys can get the best essay writing websites if you just visit the link. There are numbers of options you can find for all your requirements. So don't get shy and contact us wherever you need it.
