why does the loop in Keil run one more time?
Hi
I use designStart cortex-m3 with ram and rom which inplemented by the internal ram in FPGA board.
And then I successfully connect it with Keil through JTAG.
And I try to run the simple function below:
uint8_t i = 0;
uint8_t k = 50;
for(i = 0;i < 10; i++)
    k--;
while(1);
I set a breakpoint in while(1)
when program run to here, the i is 11 and k equals 39...
and if I set a breakpoint at the start of for loop and run step by step,
the i and k is correct( i = 10,k = 40)
could anybody help me with this problem?
