I switched on my MPS2+ board on after it was not used for a few month.
But it doesn't work and the log file shows the error message
"ERROR: FPGA did not respond to reset. Failed to program FPGA..."
Any ideas what could have happened?
BR,
Rainer
Hi Rainer,
Could you confirm that it did initially boot-up with the stock image and now it's failing with the same image? Have you got the SD card in the right slot properly anchored?
Mahesh
