When using fabric(1), i set "env.use_ssh_config = True" in my fabric.py file and it read my host ~/.ssh/config file and worked to connect to remove hosts.
Now i am trying fabric3 with Python 3.8. Since "env" is gone and "os.environ" done have an option (or i am not aware) to set to read the ~/.ssh/config file, i am unable to use it.
I have tried to add this "Config.load_ssh_config" in my fabric.py file, but still no help.
#!/Users/fab3/venv/bin/python from fabric import Connection, Config from fabric import task from paramiko.config import SSHConfig import sys import os import pprint Config.load_ssh_config @task def test(c): c.run('hostname') print(c.host) c.run('uname -a')
If anyone got this working, would you please shed some light. Appreciate your help on this. I am using the fabric3 in the virtualenv.
Thank you.
