How to put Juno into Sleep-state
I'm using Linaro Release 15.12 LSK (without OP-TEE) + OpenEmbedded Minimal Filesystem on Juno-r1 Board.
I'm trying to put the Juno board into the Sleep-state referring to ARM Versatile Express Juno r1 Development Platform Technical Reference Manual.
But it seems to reboot and fall into the error state, even if I push the Soft Reset button briefly.
Does anyone know how to put the Juno board into the Sleep-state ?
Thank you for your help.
Moderator edit: As of release 16.05 you can follow the instructions here:
https://community.arm.com/dev-platforms/w/docs/239/system-suspend-to-ram
