ds5' armclang does not support -fprofile-instr-generate -fcoverage-mapping parameters?
LLVM’s code coverage mapping format is used to provide code coverage analysis using LLVM’s and Clang’s instrumenation based profiling (Clang’s -fprofile-instr-generate option).
  • Official doc says "armclang provides many command-line options, including most Clang command-line options as well as a number of ARM-specific options". But it seems that -fprofile-instr-generate and -fcoverage-mapping are not supported.
