Hello,For my bachelor thesis I have to implement the RTL-Code of the Cortex-M3 in the DE-10 Standard Board.The FPGA on the Terasic DE-10 Standard is the Cyclone V 5CSXFC6D6F31C6.If I try to compile the ".sof" file of the Eval package in Quartus Prime file, I get the error that there are not enough i/os (430 required, 288 available).If I try it on the Terasic DE2-115 with the Cyclone IV EP4CE115F29C7N I get the error "can't place all RAM cells in design".My questions:Is it possible to adapt the design to the I/O and/or the RAM-structure?Do I have to do that manually in Quartus Prime?
I think if there are similar files in both deliverables, then the SSE-050 ones will be the ones you need.
I thought that the subsystem is just around the processor to edit and extend the design? Or how can I understand it?
