MPS2+ problem with using openocd
I'm having problems connecting the MPS2+ FPGA Prototyping Board to a VM in VMware. Ubuntu VM in VMware recognizes the connection to the MPS2+, but I'm having problems when I try to use openocd, which doesn't directly connect to the MPS2+.
I found the question in the community and used the config file from the answer.
# Main file for MPS2+
set CHIPNAME MPS2
set CPUTAPID 0x0BA04477
# Load the interface configuration
source [find interface/cmsis-dap.cfg]
# Select transport
transport select swd
# Define the target
set _CHIPNAME.cpu cortex_m
target create $CHIPNAME.cpu cortex_m -endian little -dap $CHIPNAME.dap -expected-id $CPUTAPID
# Configure the target
$_CHIPNAME.cpu configure -event gdb-attach { halt }
# Set the adapter speed
adapter speed 1000
# Set delays on reset lines
adapter_nsrst_delay 200
But got the following error.
I'm not sure where the problem is, is there a solution for this?
