AHB Lite Response
Hi All,
                           I have doubt in ahb_lite hresp signaling when the address phase is extending.
In the following diagram transfer address c is extending because of data phase of B.
In 3rd clk cycle address C is sampled so that shall we expect the hresp on 4th clk cycle or 5 th clk cycle.
But data for address C is sampling in 5 th clk cycle .
Please some one explain the relation for the hresp signal ....
Is it only related with haddr or haddr and hready also ?
Thanks & Regards
Muthuvenkatesh
  • From ARM AMBA 5 AHB Protocol Specification (AHB5, AHB-Lite)
    Chapter 5.1 Slave transfer responses
    HRESP (signal direction -> from slave to master)
    0        OKAY         (normal transfer)
    1        ERROR     (error during transfer)
    HRESP relates to HREADY (which is used by slave to inform master about extended transfer):
    HRESP   HREADY   transfer type
    0             0                pending transfer
    0             1                successful transfer completed
    1             0                error response, first cycle
    1             1                error response, second cycle
