EMBEDDED C - Volatile qualifier does not matter in my interrupt routine
I am new to embedded C, and I recently watched some videos about volatile qualifier. They all mention about the same things. The scenarios for the use of a volatile qualifier :
  1. when reading or writing a variable in ISR (interrupt service routine)
  2. RTOS application or multi thread (which is not my case)
  3. memory mapped IO (which is also not my case)
My question is that my code does not stuck in the `whiletest();`function below
 when my UART receives data and then triggers the `void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)` interrupt function
int test;
int main(void)
  test = 0;
  MX_GPIO_Init();
  MX_USART1_UART_Init();
  HAL_UART_Receive_IT(&huart1, (uint8_t *)&ch, 1);
  while (1)
                Delay(500);
                printf("the main is runing\r\n");
        whiletest();
        if(huart->Instance == USART1)
        Test = 1;
void whiletest(void)
int count =0;
while(!test){
 count++;
 printf("%d\r\n",count);
 Delay(2000);
I use keil IDE and stm32cubeIDE. I learned that the compiler would optimize some instructions away if you choose the o2 or o3 optimization level. Therefore, I chose the o2 level for build option, but it seems no effect on my code. The compiler does not optimize the load instruction away in the while loop and cache the test value `0` in the main function as the videos teach on youtube. It is confusing. In what situation I am supposed to use volatile qualifier while keep my code optimized (o2 or o3 level).zed (o2 or o3 level)
note: I am using stm32h743zi (M7)
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
