Understanding of the clock cycle activity for LPC1114
I am now working with the LPC1114 which utilizes the ARM CORTEX M0 architecture. I have one question about the instruction set summary of the ARMv6M Thumb instruction set. I want to know what the processor does during each single clock cycle for each instruction. For example, if I have the following code where I want to write something to the GPIO0DATA register to change the level of the IO output (Actually toggle PIO0_3)
loop
LDR R0, =(0x50003FFC); GPIO0DATA Base + 0x3FFC, address 0x5000 3FFC
LDR R1, [R0];
MOVS R2, #(1<<3);
; Store the value of R1 into GPIO0DATA
EORS R1, R1, R2;
STR R1, [R0];
B loop
Question 1:
Let's say the first clock cycle is when the chip fetches the LDR R0, =(0x50003FFC) instruction. Could you please explain what the chip does in the following clock cycles? Also if there is any reference that could explain it, that will be really helpful.
Question 2:
I find that the time between PIO0_3 is toggled every 15 cycles. However, based on the instruction set summary, it should be 11 cycles (LDR/STR takes two cycles and MOVS, EORS takes 1 cycle, B takes 3 cycles), could you please give an explanation? If there is a timing diagram to explain it, that would be great!
Thank in advance
Regards
Sol
