Has anyone used nic400 to configure outstanding capabilities? My current configuration: Master configures issue capability 16, slave receives 16,
but switch0 stops after sending 3 (ASIB's AREADY is pulled down), and has to wait until the end of one write data before sending it again, and the
follow-up is to write a data, the switch sends an address to the slave. There is no outstanding function at all. Can anyone give me some advice?
below is config info:
only send from mater0 to slave0
View all questions in Community Help forum
