"无源":错误:命令行:#564:无法打开嵌入式装配器输出文件"C:[用户][应用数据]本地+温度]p6550-:没有此类文件或目录
Google translate tells me:
"Passive": Error: Command line: #564: Unable to open the embedded assembler output file "C:\User\Application Data\Local + Temperature] p6550-: No such file or directory
I think we'll need more context. What are you using and what are you trying to do? You have a missing file, but I'm not sure which one, and if it should be there...
我用的是keil5,在测试我的一个工程是否能用,但是他显示错误,我的工程不能运用
You're using keil5, but is this the first error? If it's an output file, has it failed to build, and is there an error about that?
What is trying to open the file?
非常不好意思,我是一个初学者,好多东西都不太理解,我现在已经重新建立了一个账户,重新下载了keil5,把这个问题解决了,你能教教我怎么建立一个新的工程吗
I'm not actually familiar with keil, I'm from a different part of Arm, but looks like there's a Getting Started guide on here: https://www2.keil.com/mdk5/docs - but I can't see any Chinese language docs, so might need to work out translation...
I'll see if I can find someone from the Keil team to see if they have any appropriate documentation.
