Store PC to different from memory and register?
I,m using keil uVison4.22 and the device is arm7 ,I am testing about SubroutineCall,but found a doubt that the code store the r15(PC) to the address r13 of memory,and the value is PC + 12 ,if i use mov instructions to anyOne register is PC + 8 correct . but why?
AREA SubroutineCall,CODE,READWRITE
	ENTRY
	ADR r13,Stack
	SUB r13,r13,#4
	STR r15,[r13]
	B Target
	MOV r0,#0xFF
	MOV r0,#0x18
	LDR r1,=0x20026
	SVC #123456
Target MOV r1,#0xAA
	LDR r12,[r13],#+4
	SUB r12,r12,#4
	MOV r15,r12
	AREA SubroutineCall,DATA,READWRITE
	SPACE 64
Stack DCD 0x00000000
	END
so, what is the different store PC into between memory and register? because of the pipeline?
