online test of register RAM and Flash?
Hi ARM,
How to test registers,Flash and RAM during running ? Cortex-M4?
Do you have related library to support this kind of problem?
Thank
  • There should be someone to execute your logic, normally the CPU
    if the running RTOS/App is controlled by yourself, you can read/write those memory mapped registers as memory on M4
