使用ds5 调试时 只有一个核在运行
我使用的是Altera 的fpga  里面有两个arm-a9内核  可是当我调试时总是只有一个在运行 不知如何唤醒另一个。
如图 A9_1始终不能运行
.ds文件
# Copyright Altera 2013
# All Rights Reserved
# File: preloader.ds
# stop processor if running
reset system
stop
wait 5s
set semihosting enabled 0
# load the preloader (a.k.a the spl from our uboot dist)
loadfile "$sdir/uboot-socfpga/spl/u-boot-spl" 0x0
# set pc to entry point
set debug-from *$entrypoint     # Set start-at setting to address of $entrypoint
start
# delete any breakpoints
delete
# set hw breakpoint in spl in function, spl_boot_device,
# The function, spl_boot_device, is called right before the spl tries
# to load.  We stop here so we don't have to change any spl.
tbreak spl_boot_device
# tell target to continue executing spl
cont
# wait for breakpoint
wait 60s
下面是我startup.s 代码
;                                    EXCEPTION VECTORS & STARTUP CODE
; File      : startup.s
; For       : Cortex A9 on Altera SOC
; Toolchain : ARMCC
;                                           MACROS AND DEFINITIONS
                                ; Mode, correspords to bits 0-5 in CPSR
MODE_BITS   EQU  0x1F           ; Bit mask for mode bits in CPSR
USR_MODE    EQU  0x10           ; User mode
FIQ_MODE    EQU  0x11           ; Fast Interrupt Request mode
IRQ_MODE    EQU  0x12           ; Interrupt Request mode
SVC_MODE    EQU  0x13           ; Supervisor mode
ABT_MODE    EQU  0x17           ; Abort mode
UND_MODE    EQU  0x1B           ; Undefined Instruction mode
SYS_MODE    EQU  0x1F           ; System mode
                                ; Control register C1
CTRL_C1_M    EQU  0x0001
CTRL_C1_A    EQU  0x0002
CTRL_C1_C    EQU  0x0004
CTRL_C1_W    EQU  0x0008
CTRL_C1_S    EQU  0x0100
CTRL_C1_R    EQU  0x0200
CTRL_C1_Z    EQU  0x0800
CTRL_C1_I    EQU  0x1000
CTRL_C1_V    EQU  0x2000
CTRL_C1_RR   EQU  0x4000
                               ; Auxiliary control register C1
AUX_C1_FW    EQU  0x0001
AUX_C1_SMP   EQU  0x0040
                               ; Level 1 page table descriptor templates
TTB_ENTRY_SUPERSEC_FAULT  EQU  0x50006
TTB_ENTRY_SUPERSEC_STRONG EQU  0x50C02
TTB_ENTRY_SUPERSEC_DEV  EQU    0x50C06
TTB_ENTRY_SUPERSEC_NORM EQU    0x55C06
    IMPORT OS_CPU_ARM_ExceptUndefInstrHndlr
    IMPORT OS_CPU_ARM_ExceptSwiHndlr
    IMPORT OS_CPU_ARM_ExceptPrefetchAbortHndlr
    IMPORT OS_CPU_ARM_ExceptDataAbortHndlr
    IMPORT OS_CPU_ARM_ExceptIrqHndlr
    IMPORT OS_CPU_ARM_ExceptFiqHndlr
    IMPORT BSP_DCacheInvalidateAll
    IMPORT BSP_SCUEn
    IMPORT BSP_SCUInvalidateAll
    PRESERVE8
    AREA  StartUp,CODE,READONLY
    ENTRY
    EXPORT Start
Start
Vectors
    LDR     PC, [PC,#24]    ; Absolute jump can reach 4 GByte
    LDR     PC, [PC,#24]    ; Branch to undef_handler
    LDR     PC, [PC,#24]    ; Branch to swi_handler
    LDR     PC, [PC,#24]    ; Branch to prefetch_handler
    LDR     PC, [PC,#24]    ; Branch to data_handler
    DCD     0
    LDR     PC, [PC,#24]    ; Branch to irq_handler
    LDR     PC, [PC,#24]    ; Branch to fiq_handler
    DCD    Reset_Handler
    DCD    OS_CPU_ARM_ExceptUndefInstrHndlr
    DCD    OS_CPU_ARM_ExceptSwiHndlr
    DCD    OS_CPU_ARM_ExceptPrefetchAbortHndlr
    DCD    OS_CPU_ARM_ExceptDataAbortHndlr
    DCD    0
    DCD    OS_CPU_ARM_ExceptIrqHndlr
    DCD    OS_CPU_ARM_ExceptFiqHndlr
    EXPORT Reset_Handler
Reset_Handler   FUNCTION {}
    CPSID    i
    MRC     p15, 0, r0, c1, c0, 0                    ; Read control register
    BIC     r0, r0, #CTRL_C1_M                       ; Disable MMU
    BIC     r0, r0, #CTRL_C1_C                       ; Disable data cache
    BIC     r0, r0, #CTRL_C1_Z                       ; Disable branch prediction
    BIC     r0, r0, #CTRL_C1_I                       ; Disable instruction cache
    MCR     p15, 0, r0, c1, c0, 0                    ; Write control register
    ISB
    DSB
                                                     ; Init unused cores
    MRC     p15, 0, r0, c0, c0, 5                    ; Read CPU ID
    ANDS    r0, r0, #0x03
    BNE     Parking
    IMPORT  ||Image$$IRQ_STACK$$ZI$$Limit||
    BIC     r0, r0, #MODE_BITS                       ; Clear the mode bits
    ORR     r0, r0, #IRQ_MODE                        ; Set IRQ mode bits
    MSR     cpsr_c, r0                               ; Change the mode
    LDR     sp, =||Image$$IRQ_STACK$$ZI$$Limit||     ; End of IRQ_STACK
    IMPORT  ||Image$$FIQ_STACK$$ZI$$Limit||
    ORR     r0, r0, #FIQ_MODE                        ; Set FIQ mode bits
    LDR     sp, =||Image$$FIQ_STACK$$ZI$$Limit||     ; End of FIQ_STACK
    IMPORT  ||Image$$ABT_STACK$$ZI$$Limit||
    ORR     r0, r0, #ABT_MODE                        ; Set ABT mode bits
    LDR     sp, =||Image$$ABT_STACK$$ZI$$Limit||     ; End of ABT_STACK
    IMPORT  ||Image$$UND_STACK$$ZI$$Limit||
    ORR     r0, r0, #UND_MODE                        ; Set UND mode bits
    LDR     sp, =||Image$$UND_STACK$$ZI$$Limit||     ; End of UND_STACK
    IMPORT  ||Image$$SYS_STACK$$ZI$$Limit||
    ORR     r0, r0, #SYS_MODE                        ; Set SYS mode bits
    LDR     sp, =||Image$$SYS_STACK$$ZI$$Limit||     ; End of SYS_STACK
    IMPORT  ||Image$$SVC_STACK$$ZI$$Limit||
    MRS     r0, cpsr                                 ; Original PSR value
    ORR     r0, r0, #SVC_MODE                        ; Set SVC mode bits
    LDR     sp, =||Image$$SVC_STACK$$ZI$$Limit||     ; End of SVC_STACK
    LDR     r0,=Vectors                          ; Set vector table location-----------------------------------------------------
    MCR     p15, 0, r0, c12, c0, 0
    BIC     r0, r0, #CTRL_C1_V                       ; Disable high vector
    MOV     r0, #0x0
    MCR     p15, 0, r0, c7, c5, 6                    ; Invalidate branch predictor
    MOV     r0, #0x0
    MCR     p15, 0, r0, c8, c7, 0                    ; Invalidate TLB
    MOV     r0, #0
    MCR     p15, 0, r0, c7, c5, 0                    ; Invalidate instruction cache
    BL BSP_DCacheInvalidateAll
                                                     ; Set domain access
    MRC     p15, 0, r0, c3, c0, 0
    LDR     r0, =0x55555555
    MCR     p15, 0, r0, c3, c0, 0
                                                     ; Set access permission for VFP & NEON
    MRC     p15, 0, r0, c1, c0, 2
    ORR     r0, r0, #(0xF << 20)
    MCR     p15, 0, r0, c1, c0, 2
    ISB
                                                     ; Start the VFP and NEON engine
    MOV     r0, #0x40000000
    VMSR    FPEXC, r0
                                                     ; Setup page table.
    IMPORT ARMv7Attbl_SuperSecMap
    IMPORT ||Image$$PAGE_TABLE$$ZI$$Base||
    LDR     r4, =||Image$$PAGE_TABLE$$ZI$$Base||
                                                     ; Map the entire memory as device by default
    MOV     r0, r4
    MOV32   r1, #TTB_ENTRY_SUPERSEC_DEV
    MOV32   r2, #0x00000000
    MOV32   r3, #0x00000000
    BL      ARMv7Attbl_SuperSecMap
    MOV     r0, r4
    MOV32   r1, #TTB_ENTRY_SUPERSEC_NORM            ; Map SDRAM as normal memory
    MOV32   r2, #0x01000000
    MOV32   r3, #0x39000000
    MCR     p15, 0, r4, c2, c0, 0
    DSB
    ORR     r0,  r0, #CTRL_C1_M                      ; Enable MMU, See note #3
    DSB
    BL      BSP_SCUEn                                ; Enable the SCU
    MOV     r0, #0
    MOV     r1, #0xF
    BL      BSP_SCUInvalidateAll                     ; Invalidate SCU data
                                                     ; Join SMP & enable maintenance broadcasts, See note #4
    MRC     p15, 0, r0, c1, c0, 1
    ORR     r0, r0, #AUX_C1_SMP
    ORR     r0, r0, #AUX_C1_FW
    MCR     p15, 0, r0, c1, c0, 1
    DSB
                                                     ; Disable ECC error interrupts since the preloader may not init the ram
    IMPORT  BSP_IntSrcDis
    MOV     r0, #71
    BL      BSP_IntSrcDis
    MOV     r0, #210
    BL      BSP_IntSrcDis
	IMPORT	InitOS
    LDR     r12,=InitOS                              ;初始化之后  等待FPGA_OS系统唤醒
    BX      r12
    ENDFUNC
Parking FUNCTION
    WFI
    B .
    ENDFUNC
    END
我想知道这是为什么  如何启动另一个。谢谢!
