一个关于CMSIS-NN内核的arn-nn库与tensorflow行为加速度识别的参数对接问题
# coding: utf-8
# In[1]:
import pandas as pd
import numpy as np
from scipy import stats
from sklearn.metrics import precision_score, recall_score, f1_score, confusion_matrix, roc_curve, auc
import tensorflow as tf
# In[2]:
# 加载数据集
def read_data(file_path):
    column_names = ['user-id', 'activity', 'timestamp', 'x-axis', 'y-axis', 'z-axis']
    data = pd.read_csv(file_path, header=None, names=column_names)
    #data = data.sample(n=100000, axis=0)
    return data
# 数据标准化
def feature_normalize(dataset):
    mu = np.mean(dataset, axis=0)
    sigma = np.std(dataset, axis=0)
    return (dataset - mu) / sigma
# 创建时间窗口,90 × 50ms,也就是 4.5 秒,每次前进 45 条记录,半重叠的方式。
def windows(data, size):
    start = 0
    while start < data.count():
        yield start, start + size
        start += (size / 2)
        start = int(start)
# 创建输入数据,每一组数据包含 x, y, z 三个轴的 90 条连续记录,
# 用 `stats.mode` 方法获取这 90 条记录中出现次数最多的行为
# 作为该组行为的标签,这里有待商榷,其实可以完全使用同一种行为的数据记录
# 来创建一组数据用于输入的。
def segment_signal(data, window_size=90):
    segments = np.empty((0, window_size, 3))
    labels = np.empty((0))
    print(len(data['timestamp']))
    count = 0
    for (start, end) in windows(data['timestamp'], window_size):
        print(count)
        count += 1
        x = data["x-axis"][start:end]
        y = data["y-axis"][start:end]
        z = data["z-axis"][start:end]
        if (len(dataset['timestamp'][start:end]) == window_size):
            segments = np.vstack([segments, np.dstack([x, y, z])])
            labels = np.append(labels, stats.mode(data["activity"][start:end])[0][0])
    return segments, labels
# In[3]:
# 初始化神经网络参数
def weight_variable(shape):
    initial = tf.truncated_normal(shape, stddev=0.1)
    return tf.Variable(initial)
# 初始化神经网络参数
def bias_variable(shape):
    initial = tf.constant(0.0, shape=shape)
# 执行卷积操作
def depthwise_conv2d(x, W):
    return tf.nn.depthwise_conv2d(x, W, [1, 1, 1, 1], padding='VALID')
# 为输入数据的每个 channel 执行一维卷积,并输出到 ReLU 激活函数
def apply_depthwise_conv(x, kernel_size, num_channels, depth):
    weights = weight_variable([1, kernel_size, num_channels, depth])
    biases = bias_variable([depth * num_channels])
    return tf.nn.relu(tf.add(depthwise_conv2d(x, weights), biases))
# 在卷积层输出进行一维 max pooling
def apply_max_pool(x, kernel_size, stride_size):
    return tf.nn.max_pool(x, ksize=[1, 1, kernel_size, 1],
                          strides=[1, 1, stride_size, 1], padding='VALID')
# In[4]:
dataset = read_data('C:\\Users\\Leonard\\Desktop\\desktop files\\WISDM_ar_v1.1\\1.txt')
dataset['x-axis'] = feature_normalize(dataset['x-axis'])
dataset['y-axis'] = feature_normalize(dataset['y-axis'])
dataset['z-axis'] = feature_normalize(dataset['z-axis'])
segments, labels = segment_signal(dataset)
labels = np.asarray(pd.get_dummies(labels), dtype = np.int8)
# 创建输入
reshaped_segments = segments.reshape(len(segments), 1,90, 3)
# In[5]:
# 在准备好的输入数据中,分别抽取训练数据和测试数据,按照 70/30 原则来做。
train_test_split = np.random.rand(len(reshaped_segments)) < 0.70
train_x = reshaped_segments[train_test_split]
train_y = labels[train_test_split]
test_x = reshaped_segments[~train_test_split]
test_y = labels[~train_test_split]
# 定义输入数据的维度和标签个数
input_height = 1
input_width = 90
num_labels = 6
num_channels = 3
batch_size = 10
kernel_size = 60
depth = 60
# 隐藏层神经元个数
num_hidden = 1000
learning_rate = 0.0001
# 降低 cost 的迭代次数
training_epochs = 8
total_batchs = reshaped_segments.shape[0] // batch_size
# In[6]:
# 下面是使用 Tensorflow 创建神经网络的过程。
X = tf.placeholder(tf.float32, shape=[None,input_height,input_width,num_channels])
Y = tf.placeholder(tf.float32, shape=[None,num_labels])
c = apply_depthwise_conv(X,kernel_size,num_channels,depth)
p = apply_max_pool(c,20,2)
c = apply_depthwise_conv(p,6,depth*num_channels,depth//10)
shape = c.get_shape().as_list()
c_flat = tf.reshape(c, [-1, shape[1] * shape[2] * shape[3]])
f_weights_l1 = weight_variable([shape[1] * shape[2] * depth * num_channels * (depth//10), num_hidden])
f_biases_l1 = bias_variable([num_hidden])
f = tf.nn.tanh(tf.add(tf.matmul(c_flat, f_weights_l1),f_biases_l1))
out_weights = weight_variable([num_hidden, num_labels])
out_biases = bias_variable([num_labels])
y_ = tf.nn.softmax(tf.matmul(f, out_weights) + out_biases)
loss = -tf.reduce_sum(Y * tf.log(y_))
optimizer = tf.train.GradientDescentOptimizer(learning_rate = learning_rate).minimize(loss)
correct_prediction = tf.equal(tf.argmax(y_,1), tf.argmax(Y,1))
accuracy = tf.reduce_mean(tf.cast(correct_prediction, tf.float32))
cost_history = np.empty(shape=[1], dtype=float)
# In[8]:
# 开始训练
with tf.Session() as session:
    session.run(tf.global_variables_initializer())
    # 开始迭代
    for epoch in range(training_epochs):
        for b in range(total_batchs):
            offset = (b * batch_size) % (train_y.shape[0] - batch_size)
            batch_x = np.array(train_x[offset:(offset + batch_size), :, :, :])
            batch_y = np.array(train_y[offset:(offset + batch_size), :])
            _,c = session.run([optimizer, loss], feed_dict={X: batch_x, Y: batch_y})
            cost_history = np.append(cost_history, c)
        print ("Epoch {}: Training Loss = {}, Training Accuracy = {}".format(epoch, c, session.run(accuracy, feed_dict={X: train_x, Y: train_y})))
    y_p = tf.argmax(y_, 1)
    y_true = np.argmax(test_y, 1)
    final_acc, y_pred = session.run([accuracy, y_p], feed_dict={X: test_x, Y: test_y})
    print ("Testing Accuracy: {}".format(final_acc))
    temp_y_true = np.unique(y_true)
    temp_y_pred = np.unique(y_pred)
    np.save("y_true", y_true)
    np.save("y_pred", y_pred)
    print ("temp_y_true", temp_y_true)
    print ("temp_y_pred", temp_y_pred)
    # 计算模型的 metrics
    print ("Precision", precision_score(y_true.tolist(), y_pred.tolist(), average='weighted'))
    print ("Recall", recall_score(y_true, y_pred, average='weighted'))
    print ("f1_score", f1_score(y_true, y_pred, average='weighted'))
    print ("confusion_matrix")
    print (confusion_matrix(y_true, y_pred))
    print(out_weights)
    print(out_biases)
    print(f_weights_l1)
    print(f_biases_l1)
    variable_names = [v.name for v in tf.trainable_variables()]
    values = session.run(variable_names)
    for k,v in zip(variable_names, values):
        print("Variable: ", k)
        print("Shape: ", v.shape)
        print(v)
以上为python代码,建立了一个卷积神经网络模型
想请问一下,就这个神经网络模型而言,应该具体将那些池化和卷积的参数,以什么样的格式,写入参数中,如想把以上py文件中模型写入cortexm4或m7处理器,还需要怎样的分离剥离与格式转换工作啊?
