1 Reply Latest reply: May 8, 2014 7:35 AM by sellis RSS
Does DS-5 support off-target simulation of freescale vybrid VF6xx systems?
amarti Bit
In the GETTING STARTED GUIDE of ARM DS-5 is stated that "DS-5 provides Cortex ®-A8, quad-core Cortex-A9, and AEMv8 (DS-5 Ultimate Edition only)
executables. You can also connect to a variety of other ARM and third-party simulation models."
What other simulation models are provided? What about the Freescale vybrid VF6xx systems (combines Cortex A5 and Cortex M4)?
  • Re: Does DS-5 support off-target simulation of freescale vybrid VF6xx systems?
    sellis Employee
    You are correct that we only supply the few models that you mentioned above with DS-5. These provide a quick way to run small code snippets and to run the included example programs.
    DS-5 connects to models through what is known as the CADI interface. In theory it should be possible to connect any model that supports CADI to DS-5. ARM sells other CADI models separately, but typically these model development boards produced by ARM. ARM certainly does not produce a model of Vybrid, and I am not aware of anyone else providing such a model either.
